how do i find out if my cluster is a H, D or a G?! i'm thinkin of gettin the gauge sweep done..
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 5K6 920 870 D HW: 5K6 920 870 D
Component: KOMBI H03 0305
Serial number: 00000000000000
Coding: 370D00
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
No fault code found.
Has anyone used a VAG-COM to disable the TPMS (Tire-pressure monitoring system) on a mk6 golf/gti? If you have could you post what steps you did to deactivate the TPMS?
Thanks in advance for your time and advice.
Reason why i am asking…
I just took off my winter stock steelies and put on my 18" audi wheels. The audi wheels don't have the TP sensors so i'm stuck with the TPMS error light always on.
What do you mean by cornering lights using fogs?I had my car at the shop this morning getting the APR Stage 1 ECU upgrade (yippeeeeee!!!!!). Chatted with the installer about VAG COM and he pulled out his laptop and plugged in. He did a few things for me:
1. Windows up with remote (works fine)
2. Cornering lights using fogs (works)
3. Emergency braking activate 4 ways (haven't tried it yet)
But he tried to deactivate the seatbelt warning chime and it gave an error (didn't accept the change).
I didn't want to spend much time with him tinkering since he wasn't charging me.
Why would the car not accept the change to deactivate the seatbelt chime? Anything to do with the field below that option (location set to Canadian)?
I ALWAYS wear my seatbelt. But I put the belt on after I turn the ignition. The chime bugs me. How do I turn it off???
What exactly does the auto-lock setting do? I have not done that one because I was unsure what would change.
Anybody know how to code for exterior LEDs?
