plugs and everything are due at 40k, here are the service intervals with everything they do...
https://sites.google.com/site/cabgti/resources-1/resources#_Toc323647906
Well, here is what I got for 40K from the VW dealer I went for the DSG service:
Airbag system - visual check
Battery - check
Body: Visual Inspection for Corrosion
Brakes: Inspect brake system and shock absorber for leaks and damage, check thickness of brake pads, brake disc condition and check brake fluid level
CV joints: Check for leaks and damage
Coolant level and frost protection: Check
Door checks and mounting pins - lubricate
Dust and pollen filter: Replace
Engine and engine compartment components: Check ( from above ) for leaks and damage
Engine and engine compartment components: Check ( from below ) for leaks and damage, check transmission, final drive, and drive shaft boots
Engine oil - change
Engine oil filter - change
Exhaust system - check for damage and leaks
Headlights - check and adjust if necessary
Interior lighting and glove box lights, cigarette lighter / power outlets, horn, and all warning lamps: Check
Lighting: Front and rear lights, luggage compartment lighting, turn signals, hazard warning lights, daytime running lights, curve lighting, and automatic headlights: Check
Power steering - check fluid level
Rear window: check cleaning nozzle functionality (if applicable)
Ribbed V-belt: Check condition (if applicable)
Service interval display - Reset (if applicable)
Service sticker: Enter the date of the next service on the service sticker and apply to windshield
Sunroof and panoramic sunroof: Check, clean, and lubricate ( if applicable )
Sunroof: Open sunroof and check front water drains and clean if necessary (if applicable)
Test drive: Check braking, kick-down, steering, electrical, heating and ventilation systems, air conditioning, and handling
Tie rod ends: Check for excessive play, check boots
Tires: Check tread depth, condition wear pattern and pressure of all tires (including spare)
Tires: Rotate front to rear
Transmission: DSG (non-Automatic): Change fluid and filter
Underbody sealant - inspect for damage
Windshield washers, headlight cleaning system, and wiper blades: Check for damage and function, check fluid level and add if necessary
And for 60K miles:
Air filter element and snow filter: Replace and clean housing
Battery - check
Engine oil - change
Replace spark plugs
