Old 04-27-2016, 05:23 PM   #1
austinm2011
austinm2011's Avatar
OEM roof rack + wood slats. help with fabrication of rack inserts
I have the OEM roof rack on my 2-door GTI, I want to make wooden slats for the rack (mainly aesthetic, but possibly also include hooks for luggage) as I have a wood hatch as well. I have access to both a metal lathe and 3d printer, one or both of which I plan to use to make the inserts, then I would attach the wood to the inserts.
Any ideas/input on this?
Does anyone have a link to specs for the rack slot opening? maybe even a 3d printer file for inserts? plastic may be too brittle in which case I would opt for lathing the inserts.
I am thinking 6 or 8 slats would be ideal, and instead of making each slat a seperate piece, or making all of them one piece, I think making two identical inserts with 3 or 4 slats each would be easiest for install/removal/storage. Hopefully this makes sense, very open to ideas, if it doesn't make sense I can draw up a schematic
black, blue, woodgrain
austinm2011 is offline   Reply With Quote
Old 04-27-2016, 05:31 PM   #2
luvdagators
luvdagators's Avatar
Drives: 13 CW Autobahn GTI (o\!/o)
Location: Corner of grey street and the end of the world NC
Pull this off your my new hero, much awesomeness
luvdagators is offline   Reply With Quote
Old 04-29-2016, 08:40 PM   #3
I used a couple carriage bolts on each side, the square shank fits perfectly in the channel. I want to say 9/16" bolts but I have to check. Once the sides are on you can screw more pieces to them.
Old 04-30-2016, 02:46 PM   #4
luvdagators
Keep us updated
Sent from my dumb phone using Tapatalk
build, custom, roof, roof rack, wood
