Old 02-08-2013, 07:59 PM   #1
TuneMeRight
Drives: 2013 Golf R, 2005 Golf TDI
Dyno Results: Euro Tuning Boxes
• Tested at DynoEdge Albuquerque, 2wd (Haldex Unplugged)
• Tested by Hoyt, best of 2-3 pulls in 4th Gear up to 6800 rpm
• 2013 Golf R with 1090 miles
• K&N Air Filter
February 2013
Tuning Boxes Tested at Minimum Factory Settings
• RaceChip +10% gain (rounded)
• KitPower + 5% gain (rounded)
http://m1298.photobucket.com/albumvi...9.jpg.html?o=0
http://pbckt.com/pj.O5c2Pk
Stock OEM w/ K&N Air Filter
Max Power=261.19
Max Torque=290.34
KitPower (Min. Factory Setting)
Max Power=277.63
Max Torque=313.16
RaceChip (Min. Factory Setting)
Max Power=289.31
Max Torque=316.14
April 2013
Tuning boxes will be Dyno Tested at Higher Power Settings
TuneMeRight is offline   Reply With Quote
Old 02-08-2013, 08:16 PM   #2
thedude4bides
thedude4bides's Avatar
Drives: '12 Golf R
Would you mind specifically listing the numbers for each setup?
I.e.
Stock: power/torque
Chip1ower/torque
Etc.
That'd be helpful.
Old 02-08-2013, 08:27 PM   #3
TuneMeRight
I.e.
Stock: power/torque
Chip1ower/torque
Etc.
That'd be helpful.
Read the bottom script of the Dyno Report, it's all there.
Old 02-08-2013, 08:29 PM   #4
excelevant
excelevant's Avatar
Drives: '14 5.0 Track Pack
enhance, enhance, enhance
excelevant is offline   Reply With Quote
Old 02-09-2013, 02:00 AM   #5
rebellionelite
Drives: 2013 Golf .:R RB
I can't wait till I see 40% power increases! Crank that dial up Chris! Lets see what that puppy can do!
rebellionelite is offline   Reply With Quote
Old 02-11-2013, 08:41 AM   #6
TuneMeRight
Unfortunately, being the first time at DynoEdge, we were all caught up just getting baseline pulls. For sure there are power increases with the lowest settings. Afterwards I set the Kitpower on MAX setting and had no problem hitting 127 mph on the closed road.
In April I will do a second session at DynoEdge with both boxes set at MAX, then I might attempt to run two boxes at the same time.
The RaceChip would be dedicated to the MAP and the Kitpower would be dedicated to Turbo Boost Valve and the Cam Sensor, then check and see if by using two boxes in unison if there is any higher power outputs, while checking the logs, not sure if this has ever been done, sorta curious because if it made more power, would be a very trick DIY, you would be adding two processors.
The KitPower does have a "fuller" feel because it is hooked up to three sensors, Turbo Boost Valve, MAP and Cam Sensor. It is set on max now and ready to Dyno again when I comeback in April.
The RaceChip made more power on minimum setting, but is only connected to the MAP, I also set it on max and it did not throw any engine lights, so it's also ready for the next Dyno comparison in April.
What I will do is see what box has the most power and then maybe try them together, maybe, just a wild idea.
It appears these boxes will give at least 20% increase with just a K&N filter, can't wait to find out, wish somebody in Albuquerque with an APR tune would test on the same Dyno, then could really find out if the boxes compare to flashing an ECU
Old 02-11-2013, 01:31 PM   #7
ides1056
Drives: 2013 Golf R
Moser is king...
ides1056 is offline   Reply With Quote
