When I start my car and if it is not warm it will make a squeal when I let out the clutch and let it engage. After it warms up it works fine and does not squeal. I do not have any pedal shake or feel any slipping. If I pound through the gears it works just fine. Holds nice and solid. I am new to working on cars but are good with mechanics and figuring things out. I have been told it is a throw out bearing but any research I have done on this forums or on the interwebs it says I should have pedal shake. The clutch does not feel like it is going at all and is solid. Could it be low fluid? I have not checked yet I should but not 100% where it is located to check. Still new sadly... I am learning though!! It is a older car it is a 2010. Under 100k miles still as well. Any insight would be very welcome!
It sounds like a squeal or someone said online a loud owl hoot.
