Old 06-09-2017, 07:19 PM   #197
notovicrious
notovicrious's Avatar
Drives: 2011 GTi 2.0T
What sealant did you go with? Is there an actual gasket out there to silicone on?
Old 06-09-2017, 08:00 PM   #198
rtnlsltn
Drives: MK6 GTI | 01 Ducati M750
I used the VW black liquid stuff in the caulk-gun tube. The only thing I can figure is there wasn't enough in the specific area. It's leaking at the crease between the oil pan and block. Was fine at idle, but leaks noticeably when the crankcase pressure builds while driving.
rtnlsltn is offline   Reply With Quote
Old 07-17-2017, 11:35 AM   #199
mikeysal1
Newbie
Drives: Mk6 GTI
Anyone have the pictures for this thread? Can't view them because of photobuckets p500 :/
mikeysal1 is offline   Reply With Quote
Old 07-17-2017, 12:20 PM   #200
Wrath
Drives: 2011 VW GTI DSG coupe
Im selling a kit for this on Ebay
Look at this on eBay http://www.ebay.com/itm/172749691597
Sent from my LG-D850 using Tapatalk
Wrath is offline   Reply With Quote
Old 08-03-2017, 12:53 AM   #201
Jarred767
Drives: 2011 White GTI 4DR 6MT
Same thing, I'm debating trying this out and heard that this was a great DIY, but no pictures definitely doesn't help.
Jarred767 is offline   Reply With Quote
Old 09-09-2017, 01:52 PM   #202
l0sojoslocos
Drives: wolksvagen
How to remove the serpentine belt tensioner? Got the pulley off but the tensioner is in the way of removing the timing cover. I only see one little torx bolt but it doesn't look like it holds anything on.
l0sojoslocos is offline   Reply With Quote
Old 09-15-2017, 02:29 PM   #203
rewnpdx
Newbie
Drives: 2010 TSI GTI, 2003 Passat, 99 Jetta
Hey All, I have read this thread like 10 times, anyone have links to pictures from the first post. They all have the p500 Photobucket warning. I was hoping to get some insight on this.
My GTI is throwing p0016 without any other codes, it also drives great (I had a EGR CEL and didn't notice the p0016 at first, could this be just the Tensioner is worn, or has it for sure skipped time?
Any way I could get away with just pulling the Pulley/Cover and swapping the tensioner without risking the timing?
rewnpdx is offline   Reply With Quote
Old 09-16-2017, 11:21 AM   #204
bmanc42
Drives: gti
If you use chrome on a desktop or Firefox ion mobile they both have an add on that will show the pictures. Google photobucket fix
bmanc42 is offline   Reply With Quote
