http://www.performancebyie.com/ie-mk5-mk6-2-0t-tsi-high-flow-cold-air-intake-kit
just made a purchase. intake looks well built, and as of the price how can you beat it. review coming soon
REVIEW
Packaging: everything was included, the box was packed very well and the contents were protected with wrapping
Installation: simple, no modification needed. all clamps supplied were used. I was very satisfied that the heat shield lined up, the rubber gourmets were pre-installed as well as the stripping around the heat shield.
Driving impressions:
normal driving: you can hear the induction noise very well, you can hear the turbo instantly with a push of the throttle, you don't have to get on it to hear the intake
spirited driving: simply amazing. I have had the apr stage 1 & 2 intake before and this intake sounds so much better. if you are looking for a turbo that gives you the noises of blow off, this is the one
Wide Open Throttle: on the butt dyno I definitely feel something there. based off observations on my boost gauge (mechanical) I can see I get to full boost quicker and seems to hold boost longer to the redline.
I haven't been able to do after comparisons with the torque app but I will get those when I can. for the price you cant beat it, simple as that. I based my purchased decision on a few different things. confined filter heat shield with the velocity stack. this filter measured 5". is does use the stock MAF location, no need to worry about fuel trim issues.
It's going down
REVIEW
It's going down
