xHeartcoreboyx
IceCream GTI
My fault:
Car seems to behave normally, pulls hard and no unusual noises.
I though it felt a bit slow yesterday, but this fault is like couple days back, after I removed my APR stage 2 pipe and cleaned it and also installed the NSP boost hose tap.
I double checked the stage 2 pipe to turbo coupler and fit it more properly. The tap NSP hose seems flawless.
I have the rev D piston type, these can break?
Note that the car is boosting normally…it's peaking to 26psi, holding 24psi and then around 18psi at redline, this is with the "beta" APR K04 file, it's been always like this..
Shall I be concerned? or can faults just happen like that and not come back?
1 Fault Found:
000665 - Boost Pressure Regulation
P0299 - 000 - Control Range Not Reached - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 79251 km
Time Indication: 0
Date: 2050.14.22
Time: 22:14:14
Freeze Frame:
RPM: 6222 /min
Load: 75.3 %
Speed: 122.0 km/h
Temperature: 99.0∞C
Temperature: 45.0∞C
Absolute Pres.: 1000.0 mbar
Voltage: 13.208 V
Readiness: 0010 0001
