"get pageviews or likes" what"s that?
Lol I don't think many like me here, just an old guy having fun playing/tinkering with his son's car.
We decided to install the Kinforests because they are as cheap as sh!t, we can kill 'em.
We used the stock 195-65-15 size Kinforest, they are V rated, the side walls are stiffer than the cracked up Michelin defenders that were on the car. Handling is
very lively at speed, Turn-in is good, a bit better than the Michelin or like the Conti Pure Contacts. The tires performed better than I ever thought Chinese Tires could and at a track that you feel that you are aways turning.
http://www.calabogiemotorsports.com/track/
We basically killed the 15 inch Michelins running hot laps chasing after BMW and Subies at Roebling Road track near Savanah GA, so we needed to replace them.
Everyone has different feel and drivin style, so what works for me and my Son may not be to your liking. I have the suspension setup how I like it for 15 inch tires, near neutral but has a bit of safe understeer. Setup wise nothing to write home about: F/R 34/38psi, 27mm Hotchkis rear bar set on the softest setting, 1.5 neg rear camber with a slight bit rear toe out.
Be smooth whenever the ESP or
whaever VW calls it, comes on
it slows you down, so don't go too stiff with the rear bar.
Cheers
