tom@aptuning
VW Service & Performance
***WRD Street Advantage Coil-over Kit - Only $399 - In Stock & On Sale @ APTuning***
HD KITS NOW AVAILABLE!!!- These kits have a higher rate rear spring which is ideal for larger sedans, wagons, and all wheel drive cars such as JSW, Golf R, CC, etc. They can also be used on regular models for those wanting a more sport oriented bias.
**We also install these and do alignments at very competitive prices!!**
WRD's Street Advantage coil over kits are on sale now through August 3rd for only $399!! That is a savings of $200 from retail!!
No gimmicks, no hype. I'm not gonna try to tell you these are the best coil out there or are comparable to $1K+ systems, but I honestly think they are the best entry level coil available for a couple hundred dollars. In todays world not everyone has thousands to spend on suspension so with the help of WRD we want to offer a quality kit for the average daily driver. You really can't beat the bang for the buck.
The WRD Advantage Coilovers provide a perfect balance between comfort and performance. With threaded shock body's and perches that allow you to adjust the springs to give your VW or Audi the ride height you desire, lowering the center of gravity and increasing the performance and handling. All while maintaining a budget.
Now most people will look at this and think, "Big deal, another cheap coil over kit!", but this isn't that. The WRD Advantage coil-overs have many features not found in other systems. Such as:
The WRD Advantage coils will be on hand for MK2/MK3/MK4/MK5/MK6
*Sorry there currently is no fitment for MK4 R32/TTQ or the new Jetta S model which has a smaller front strut body
**Fitment has been confirmed for Jetta models with the solid rear beam but they do not go as low in the rear as cars with the independent rear suspension
Now on to the pictures so you can see all the quality which I just described, plus a thread is worthless without pics right lol
Click HERE to place your order
- Chrome plated shock bodies - other manufactures are bare metal or nickel plating which offers little to no corrosion resistance and can leave coils junk after just one winter.
- Black powder coated springs and anodized perches - frankly they just look better and more appealing, while offering further corrosion protection.
- Spring rates and Shock valving chosen by WRD - WRD obviously knows their way around the track and suspension setup, why not go with their way rather then what some random company "thinks" will work.
- 3year Limited Warranty - This alone should give anyone piece of mind, if a reputable company in the U.S. is willing to give this length of warranty you know they stand behind the product.
