Beej1
I believe there's a way to adapt the sensor so that it would screw into where your oil drain plug would go. Or either have drop, tap and weld a bung onto the oil pan or buy a high-end oil pan that already has one.
Yeah, you can just use an M14x1.5 oil temp sensor, I would assume. My BMW E30 is set up like that. VDO makes a bazillion sensors.
