So my check engine light came on the other day. Looked up the code:
Code: P2431 " Sec Air Inj Sys Air Flw"
From what I understand its a Secondary air pump sensor that has gone bad.
I called the dealership and they said that many parts of the secondary air pump/intake had a extended warranty due to many issues with them, however they said that the sensor was not covered under the warranty :thumbdown:
I looked up some stuff on the code and it seems like people often confuse the MAP and SECONDARY AIR PUMP PRESSURE SENSOR (links below). From what I read they both look very similar but are found in different areas and cannot replace one another. Honestly no idea at this point.
Any one truly fix this issue?? Cant find any good info on it.
-- MAP Sensor -- https://www.ecstuning.com/Volkswagen-Golf_VI--2.5/Engine/Intake/Sensors/ES2678229/
-- SECONDARY AIR PUMP PRESSURE SENSOR -- http://www.jimellisvwparts.com/prod...-sensor-PRESSURESENSOR/5182456/07C906051.html
