MacRadiators
When it come to track SRF has no equals in the world of brake fluid.
a cheap BBK with oversized discs should help dissipate heat more effectively , the worse part is the added weight
350x32 ML discs are so heavy at 13.5kg/rotor
I choose a setup 340x30mm brembo discs from TTS audi + cayenne 18zl calipers.
discs are only 10kg/piece, trying to keep rotating mass as low as possible
Wheels as light as possible also help
