Boobslappy
So I installed my 42DD boost tap and New South boost gauge without issue. However, i noticed today that my headlights are always on regardless of the headlight switch position. My gauge is lighting up and dimming just Fine and i triple checked my wire taps. No fuses are blown either. Also if I unplug the headlight switch it has no effect on the headlights. SO Im assuming if you break the headlight switch the car defaults to headlights on all the time? Did i break the headlight switch removing it? I cant imagine i caused a short as I used the wire taps correctly.
