Old 05-07-2015, 01:16 PM   #1
zwalk
zwalk's Avatar
Drives: 2012 GTi Autobahn
K04 0026 Compressor on K03
Has anyone tried fitting their K03 with a different compressor and seen gains?
Just curious.
2012 GTi Autobahn ~ 2 Door Manual
zwalk is offline   Reply With Quote
Old 05-07-2015, 02:00 PM   #2
simpson110
Drives: 2013 gti
It's probably more work than it's worth. Is the chra the same between the two?
Mods: cts ko4 w/ apr v3.1, gfb dv+, HS tuning rsr, ttrs bbk, spm intercooler, dg springs, bsh race intake, spm catless dp, cts cb, nsp redline boost gauge in vent pod, vacar led tails, vagcom tweaks
Pm me for vagcom in southern ct(near new haven)
simpson110 is offline   Reply With Quote
Old 05-07-2015, 02:16 PM   #3
Chris@DoubleApex
Chris@DoubleApex's Avatar
Drives: MKIV GTI, MKV GTI, MKVI GLI
The K04-026 flows less than the stock turbo.
Chris@DoubleApex is offline   Reply With Quote
Old 05-07-2015, 02:36 PM   #4
Goingnowherefast
Goingnowherefast's Avatar
Drives: 16 GTI S 6MT, 91 Miata
You could try clipping it, though it's not really worth it. I got my K04 for $400 haha
2016 GTI S 6MT//2014 Fiesta ST 6MT//1991 Miata 5MT
Turbo miata build starting here: http://www.golfmk6.com/forums/showthread.php?t=96866
Goingnowherefast is offline   Reply With Quote
Old 05-07-2015, 02:46 PM   #5
XGC75
XGC75's Avatar
Drives: into shit
Me too!
CHRA for a k04-64 comes in at anywhere between $500 and $600 depending on where you get it. Not sure about other CHRAs, but if a slightly larger CHRA would fit into a k03 manifold and compressor housing it may be a really cost-effective way to add power. Best case scenario is you see performance a bit worse than the mk7 stage 2.
Old 05-07-2015, 03:07 PM   #6
zwalk
zwalk's Avatar
How the hell did you get a $400 K04!!
Old 05-07-2015, 06:25 PM   #7
doug@frankenturbo
Drives: FrankenTT
Just curious.
The rotating assembly in the IHI turbo you have is something a K04-026 could only dream about. If you're considering a compressor upgrade, don't go with something designed in the 1990s.
doug@frankenturbo is offline   Reply With Quote
Old 05-07-2015, 07:40 PM   #8
zwalk
zwalk's Avatar
The title was dumb, I should've just said has anyone changed the compressor
Old 05-07-2015, 07:45 PM   #9
XGC75
XGC75's Avatar
Drives: into shit
They're blown. Basically all you're buying is the exhaust manifold, compressor housing and DV relo kits. You still need to shell out $600 for the chra, $500+ for the tune, $40 for the install kit and whatever else. It's cheaper than the going rate for a used k04 but by maybe $200-$300 at best.
Old 05-08-2015, 04:57 PM   #10
zwalk
zwalk's Avatar
Then why did he say $400??
Old 05-08-2015, 05:12 PM   #11
mk6'12gti
Drives: 2012 4dr Black Gti
he must of gotten lucky an was able to buy a blown ko4 for 400 but he still needed to spend 500-600 on a new CHRA then the tune an install kit.
