Howcanifixthis?
Alrighty so my mk6 is leaking oil and im not sure why. My local VW dealership said it was leaking from the drain plug. So i purchased 2 drain plugs during my visit... I did an oil change and put the new plug in. I have noticed the leak has not stopped! There are stains in my driveway that are just the same as if i haven't replaced the plug.
What could be causing this or what can i do? Im really just looking for advice/opinons on causes. I will get under the car and watch for dripping oil. I already know it is coming from the seal/plug as iv'e witnessed it run and drip from there. I'd imagine if replacing the plug didn't fix it i must have another problem Should i just replace the oil pan (or whatever it is called)? Thanks
