I'm not trying to convince you otherwise, but:
Having had the 6 (I love the 6 still by the way) when you actually had one, then the other - and have it in three dimensions in front of you where you had the previous one - they are more different than they appear at a glance.
Walk around them, and the MK7 is far more contoured. (It actually appears more boxy and slab sided in photos though.
It's also significantly lower and wider.
It's the stuff the you can't see that's more notable though:
The steering being one turn quicker lock to lock.
The huge increase in torque.
The tighter body structure.
Then there's the performance pack for those who want to go that route.
The number one reason for me not to switch is the amount of headroom I get in the mk6 vs mk7. I track the mk6 and my long trunk 6'3 frame would not allow for me to fit a helmet in the mk7. I have tried and failed.
So significantly lower is not necessarily a good thing.
My gti with 265 tires on 9 inch wheels et 35 has a wider track than the mk7
You can get a quicker steering using the passat uprights
which I rock.
The k04 takes care of the torque.
Jumping from 14k to 31k from a pure performance point of view does not make sense.
New car smell... now that's something else.
I'll give you the tighter structure; but after all the bracing...
I appreciate the stilling of the mk7, but prefer the mk6 look with a better balance of soft corners. Then again looks are subjective.
Enjoy the ownership
And drive like you stole it.
