I have had my MKVI 2 door, w/ DSG since Friday...took it on the freeway and I get a weird wind noise right at the window B-pillar...on the drivers side and the passenger side...windows are up on both doors....does anyone else have this issue?
Yes it is a common problem with all MKVI. I have it on mine too, a hissing sound when traveling at a high speed, all windows and sunroof closed. Many people on the forum say that it went away after they brought it back to the dealer and adjusted the striker plate. I got mine adjusted once but the noise is still there. Will be bringing it back again for another adjustment.
I thought I intermittently had the wind noise people complained about but realized it was the blowoff valve. Haven't had a turbo for 2 years and forgot about it...
I have the same air leak from the B pillar at the highway speed. Somewhat bothersome, but not severe enough to bring it in just for this problem. I'll tell them when I bring it in for 3000 miles inspection.
If that's the case, then all of these striker adjustments are simply band-aids, tightening the door into the thinner "early" seals will only speed up the wear and tear on the rubber.
