Official APR MK6 Products and Information
Arin@APR
GOLFMK7 Official Sponsor
These are absolute figures:
Keep in mind, the values will change based on a lot of things, like temps, altitude, etc.
SnailPower
Stupid question.
I had my tune recently tweaked by my tuner dealer and they reset my passcode to 0101. How do you input a "0"? I'm assuming you just perform the sequence to register without pressing the Set button as there is no value. However this hasn't worked at all for me. Any idea?
Thanks.
lilonespaz
Stupid question.
Thanks.
scroll pass 9 and it should turn 0 right?
Mr_Dog
I noticed your specified boost and actual boost are very close values. Are they suppose to be like this? When I logged with APR Mobile, the Specified boost was always 4-8 PSI higher, is this normal?
Roaldtm
What spark plugs are recommended for the APR Stage II? It's OEM fine or something different ?
SnailPower
The Audi R8 red plugs. I believe they go for $80 total. I've had them since I went stage 1 like 4 years ago and never had an issue. Now I'm stage 2 since a year ago and no issues.
FriggenT1
Banned
Those APR figures imo are showing that WG working a lot harder than it needs to.
Mr_Dog
Do ya mind expanding a bit? Why would you think the waste gate is working harder?
I can try and post some logs with the waste gate & N75 as well. What would result in the WG working to hard?
FriggenT1
Banned
I posted a thread not too long ago on WG spring pressures, the stock spring is too weak, and guys who use the aftermarket WGs can run the same boost levels at 40% less. A wastegate spring should be right around half of what your max boost is, that's the general rule of thumb.
larryloveslala
Hey all! Apr 2.4 tuned here. 3" downpipe with high flow cat and injen cai. Getting low 9s 9.13 - 9.19s in the 8th official track timeslips using the 93 octane tune.
Anyone have number on the 100 octane tune difference before I drain the tank and pour in the race gas?
Sent from my XT1585 using Tapatalk
brobst
Question about catch can maintenance. What should I use to clean the can and what should be the frequency that I clean it?
Also it says not to fill it over halfway. What is the liquid capacity of the catch can?
Arin@APR
It’s spring and that means it’s time to get out and enjoy your car. We’ll help you do that by taking 10% off all of our ECU and TCU Upgrades¹! As an added bonus, we’ll give you 20% off our TCU Upgrade if you purchase the ECU and TCU on the same day! Take advantage of this sale between March 22nd and April 15th at all APR Dealers in the USA. For participation outside the USA, please contact a local APR Importer.
Thank you and Go APR!
¹Please Note, this sale excludes APR Plus.
cons
Arin@APR could you tell me APR K04 v3.1 software for CAWA motor (06J 906 026 AB) does use data from tiguan lambda sensor? It is not wide sensor if it is important. If yes, how this sensor can be checked or what mileage it should be replaced?
Also readiness code for lambda should be passed or not?
