Yes. One piece? From ic to turbo coupler
The pipe goes from turbo to ic to throttle body... it doesnt go ic to turbo....
And it would take a shit ton of fab work to make it 1 piece there are like 2 bends at odd angles..
from the turbo it goes down then bends to the left then back to the right into the intercooler... you wouldnt be able to fab 1 piece then put on it would have to be welded together as its on...
The intercooler does not move and your engine does. Really you would only be getting rid of one 90 degree couping and the one rubber hose that goes from the pancake to the IC. You should have these rubber hoses there for some flex between the intercooler and the hardpipes/turbo.
So no, there is no benefit.
