Kessy not working on doors
Sharino
Driving me crazy, Kessy system on 2013 GTI
Both remotes open and unlock doors but touching the handle to lock and unlock stopped working on both drivers/passenger at same time. Hatch still works keyless and car still starts with keys in my pocket. Just seems both handles died. Read a few online tricks, nothing seemed to work. New batteries, no difference.
This is what a VCDS scan shows:
Address 05: Acc/Start Auth. (J518) Labels: 5K0-959-434.clb
Part No SW: 5K0 959 434 B HW: 5K0 959 434
Component: VWKESSYPQ35GP 085 0902
Revision: 00085000 Serial number: 0178205623
Coding: 030C0C
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_KESSYPQ35G A02013
ROD: EV_KESSYPQ35G_VW01.rod
VCID: 346D07859F4F8FE268-8060
3 Faults Found:
1052936 - Touch Sensor on Exterior Door Grip; Driver Side
B116B 29 [008] - Signal Implausible
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 10
Reset counter: 141
1052939 - Touch Sensor on Exterior Door Grip; Driver Side
B116B 13 [008] - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 122
Reset counter: 142
1053195 - Touch Sensor on Exterior Door Grip; Passenger Side
B116C 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 68
Reset counter: 102
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 5K0 959 703 D HW: 5K0 959 703 D
Component: Tuer-SG 007 2101
Coding: 0001168
Shop #: WSC 01357 011 1012552
VCID: 356B3A815C3596EA5F-8060
1 Fault Found:
00930 - Locking Module for Central Locking; Rear Left (F222)
008 - Implausible Signal - Intermittent
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 5K0 959 704 D HW: 5K0 959 704 D
Coding: 0001168
VCID: 36693D8D41339DF256-8062
1 Fault Found:
00931 - Locking Module for Central Locking; Rear Right (F223)
Any ideas greatly appreciated!
