Old 02-15-2018, 01:45 PM   #1
snidehockey
Drives: 12 GTI
Stage 3 Clutch Drop In. Still slipping! :(
So I have a '12 w/ about 80k on it and decided to make the jump from stock right up to stage 2.
I got the COBB tuner and installed the downpipe a few weeks ago, and was thrilled at the power bump. Until I pushed it in 4th and saw my first slippage.
This car came from my 70 some year old father-in-law who didn't drive it hard AT ALL, so I figured (based on other users' success doing so) the components should be in good enough shape to keep the stock DMF and drop in a South Bend Stage 3 disc.
For this job I had a local shop (KDK Performance) do the work.
The owner called me up yesterday when the work was complete to let me know that the Flywheel looked to be in good shape and all seemed good until the test drive. Slipping at higher RPM's still.
With that said the clutch engagement and pedal feel is WAY different. It engages really high and at about 75-80 percent depressed, the pedal just gets ... I don't know ... hardish?
At this point I don't really know what's next. It's obviously drivable but makes every performance mod a total waste if it slips at anything over 4k rpm.
Thoughts?
snidehockey is offline   Reply With Quote
Old 02-15-2018, 01:47 PM   #2
smanierre
Drives: MK6 GTI 6-SPD Shadow Blue
Thoughts?
Did you break the clutch in?
smanierre is offline   Reply With Quote
Old 02-16-2018, 09:35 AM   #3
Rolling_GTI
Rolling_GTI's Avatar
Drives: '12 GTI
Pressure plate weak possibly. I personally don't get doing just the disc. The expensive part is the labor, you are already in there. Slave cylinders are the weakest part of our clutches, do it all while you're in there.
2012 Carbon Steel Grey GTI 6MT w/ Sunroof & Nav
APR K04 | ESC Disabled | Carbonio | COBB TBE | RR Stage 3 clutch | Scarlet Red VMR 701's 18" | Black Unibrace UB & XB | VF Engine/Tranny mounts | DG Skid Plate | S3 Short Shifter | EBC Red Pads, Slotted Rotors | Filled Hood Notch | LED Tails | 35% Tint | Too many small mods to list
I've driven her 253,000 hard miles and still loving it! 27MPG Lifetime average
Rolling_GTI is offline   Reply With Quote
Old 02-16-2018, 11:04 AM   #4
snidehockey
Drives: 12 GTI
Well the line of thinking is $386 for the disc dropped into an application that is supposed to be able to handle it just fine with no new chatter or huge pedal changes...
vs
$1100 for a whole kit that now chatters like a mofo and makes the clutch (from what I've read) much stiffer.
after reading the whole 58 page topic dedicated to the drop in, I think I see where things went awry...the shop didn't reset the pressure plate and apparently mine was the type that needs it.
see post #411
http://www.golfmk6.com/forums/showth...=43658&page=30
Old 02-16-2018, 01:44 PM   #5
Tony48
Rally Car Champion
Tony48's Avatar
Drives: 2011 GTI
If anyone else has this dilemma look into purchasing an HS Tuning RSR clutch or piecing it together yourself (DIY RSR Clutch). I pieced it together myself and the clutch has been great so far. Basically you upgrade the pressure plate and replace the clutch disc (Replace the flywheel if necessary). You wind up with a clutch rated to 480ft-lbs that retains OEM pedal feel and no chattering because you retain the OEM flywheel. I did an extensive write up with pictures on the DIY RSR clutch in my build thread.
see post #411
Here's some helpful info I bookmarked a few months back in regards to resetting the pressure plate:
| 2011 GTI, 6speed, 4dr | Build Thread| Timing Chain Replacement Tips | DIY RSR Clutch & RMS Replacement Tips|
Old 02-16-2018, 02:21 PM   #6
snidehockey
Drives: 12 GTI
You're the man. Thank you very much!
Old 02-18-2018, 10:28 PM   #7
aliasromero9
Newbie
Drives: 2013 GTI 6MT Stratified Tune 91+E30
Can confirm this setup is excellent 13,000 miles on it so far & no problems, I have this on a high torque tune & it doesn't slip at all. I bought this clutch as a kit from a local shop for about $650
aliasromero9 is offline   Reply With Quote
Old Yesterday, 04:33 PM   #8
Andrew429
Touring Car Champion
Andrew429's Avatar
Drives: 2011 GTI 2-dr
I installed mine at around 36k miles 3.5-4 years ago and now I'm just about at 68k, all of those miles were on stage 2, still feels like it did after the first 1000 miles on the clutch
APR Stage 2 | APR Stage 1 & 2 Intake | Southbend Stage 3 drop in disc | USP Downpipe | RS3 Bushings | Vag-Com Tweaks | 35% Tints | Depo Headlights | OEM LED Tails | Stock Cat-back w/Aero Resonator |
Andrew429 is offline   Reply With Quote
