tjasko
I've finally convinced myself to start a build thread... mainly because things are starting to get serious and I can barely fit all my mods in my signature anymore. :bellyroll:
I'm not new to these cars; I've had a stage 2 MK6 GTI as well, however I sadly had to part ways with it and a Golf R was my obvious next car. I found the R, went to the used car dealer, test drove it, gave the car a thorough mechanical inspection, and bought it same day back in May 2015. Fun fact: I never even test drove my GTI before buying it brand new, I knew it was exactly what I wanted.
My Golf R is built to be a daily-driven, track-ready car that can have the throttle hammered and be able to take a comfortable, leisurely cruise all at the same time.
Thanks to for everyone below getting things done on the car.
- Auto Union Tuning (shoutout to Raz & Dave)
- Blair Automotive/BMP Tuning (shoutout to Ryan, Blake, & Patrick)
- Robz Auto
- Rotaryknight
HORSEPOWER & TORQUE @ WHEELS:
393awhp • 374lbft on the IE450T kit with a Mustang dyno (current, but without the built head)
317whp • 361lbft on APR stage 2+ with a Dynapack dyno (past setup)
BOUGHT & PENDING INSTALL:
Nothing at the moment.
WISH LIST:
Black roof wrap
Radiator upgrade
TyrolSport Stage 2 Hatch Brace
ENGINE:
42DD Catch Can w/ AN Fittings & Boost Tap @ 56,497 miles
APR Intercooler @ 57,086 miles
Audi R8 Coil Packs @ 52,960 miles
Autotech High Volume Fuel Pump Upgrade Kit @ 55,608 miles
ECS Engine Oil Dipstick @ 59,928 miles
ECS Street Shield Skid Plate @ 59,928 miles
Fluidampr Engine Damper @ 59,928 miles
iABED HPFP Cam Follower to Roller Conversion Kit @ 65,013 miles
iABED Billet Aluminum Rear Main Seal @ 73,829 miles
Integrated Engineering IE450T 93 Octane w/ Intake Manifold Tune @ 71,162 miles
Integrated Engineering IE450T Big Turbo Kit (BorgWarner EFR 6758) @ 71,162 miles
Integrated Engineering IE450T Cold Air Intake @ 71,162 miles
Integrated Engineering IE450T High-Flow Catted Midpipe @ 71,162 miles
Integrated Engineering Intake Manifold @ 71,162 miles
Integrated Engineering Sport Series Performance Cylinder Head @ 74,653 miles
Milltek Catback Exhaust @ 55,608 miles
Neuspeed Turbo Charge Pipe @ 53,627 miles
Neuspeed Turbo Discharge Pipe @ 53,711 miles
NGK BKR7EIX Spark Plugs @ 71,162 miles
Soundaktor Delete @ unknown (was already unplugged)
Turbosmart IWG75 Internal Wastegate Actuator @ 71,162 miles
Turbosmart Kompact EM BOV Plumb Back VR1 @ 72,830 miles
DRIVETRAIN:
42DD Shifter Cable Support Bracket @ 72,231 miles
BSH Speedshop Mounts (engine, transmission, pendulum w/ torque mount insert) @ 55,983 miles
DieselGeek Short-throw Shifter @ 55,983 miles
South Bend Stage 3 Drag Clutch @ 78,643 miles
ECS Tuning Clutch Bleeder Block @ 71,162 miles
ECS Tuning Stainless Steel Clutch Line @ 71,162 miles
HPA Haldex Competition Controller @ 56,497 miles
BRAKES, TIRES & WHEELS:
KYO-EI 3mm spacers all around @ 63,756 miles
Michelin Pilot Sport 4 S Tires (225/35/19) @ 59,928 miles
Motul RBF600 Brake Fluid @ 55,983 miles
StopTech 310mm Slotted Rear Rotors @ 63,756 miles
StopTech Brake Pads Rear @ 55,983 miles
StopTech ST40 Trophy 355x32 Big Brake Kit @ 63,756 miles
Tyrolsport Master Bracket @ 68,549 miles
USP Motorsports Rear Stainless Steel Brake Lines @ 55,983 miles
Volk Racing G25 Dark Silver Prism Wheels (19x8 +48, 18lbs) @ 63,470 miles
Volk Racing ZE40 Custom Mag Blue (18x8.5 +44, 17lbs) - Track Wheels
SUSPENSION:
Bilstein B16 PSS-10 Coilover Kit @ 57,054 miles
Neuspeed Front Sway Bar @ 59,008 miles
Neuspeed Rear Sway Bar @ 53,627 miles
Neuspeed Rear Sway End Links @ 53,627 miles
SuperPro Front Sway Bar End Links @ 59,008 miles
SuperPro Lower Control Arms @ 59,008 miles
SuperPro Roll Control Ball Joints @ 59,008 miles
INTERIOR:
A119 Dash Cam Hard-wired @ 68,795 miles
Black Forest Industries SCHWARZ Air Leather Shift Knob @
Escort Max 360 Radar hard-wired with Blendmount @ 57,409 miles
Klii Motorwerkes Steering Wheel Badge Inlay @ 52,270 miles
P3cars Vent Digital Interface w/ analog boost sensor @ 53,517 miles installed
ProClip Phone Holder @ 52,270 miles
R Seat Lever Inserts @ 52,270 miles
SOUND SYSTEM:
iDatalink ACC-NAV2 @ 73,705 miles
iDatalink HRN-ANT-SAT1 @ 73,705 miles
iDatalink HRN-RR-VW1 @ 73,705 miles
iDatalink Maestro ADS-MRR @ 73,705 miles
JL Audio DRC-205 Digital Remote Control @ 73,902 miles
JL Audio VX1000/5i Amp @ 73,705 miles
Pioneer AVIC-W8400NEX Navigation Receiver @ 73,705 miles
Polk Audio DB+ 10" DB1042DVC Sub @ 73,705 miles
Polk Audio DB+ DB6502 6-1/2" Component System (front) @ 73,705 miles
Polk Audio MM 652 6-1/2" Speakers (rear) @ 73,705 miles
SiriusXM SXV300V1 Satellite Radio Tuner @ 73,705 miles
EXTERIOR:
APR Hood Decal (EuroCode Tuning threw on some decals for Fastivus 2015) @ 53,760 miles
DeAutoKey LED license plate lights @ 52,270 miles
Klii Motorwerkes Rear Badge Inlay @ 52,270 miles (discovered while doing this rear badge was plastidipped before)
OEM Dark Cherry LED Tails @ 52,270 miles
R Wheel Valve Stem Caps @ 52,493 miles
US Mill Works License Plate Bracket @ 52,864 miles
REMOVED PARTS:
A118-C Dash Cam Hard-wired @ 59,048 miles installed & 68,795 miles removed
APR Boost Tap @ 53,532 miles installed & 56,497 miles removed
APR Stage 1 tune (just transferred the warranty) @ unknown (came with car) & 55,608 miles removed
APR Stage 2+ Tune @ 55,608 miles installed & 71,162 miles removed
Continental DWS Tires @ unknown (came with car) & 59,928 miles removed
Deutsche Auto Parts HPFP Stud Kit @ 59,008 miles & 65,013 miles removed
DKM Stage 3 Twin Disk Clutch (rated for ~660ftlb) @ 71,162 miles & 78,643 miles removed
Eurotek 19” 02 Wheels @ unknown (came with car) & 63,470 miles removed
EZ Lip Pro @ 57,211 miles installed & 59,392 miles removed
GoFastBits DV+ @ 54,172 miles installed & 72,830 miles removed
Milltek Downpipe @ 55,608 miles installed & 71,162 miles removed
Neuspeed Intake @ 53,627 miles & 71,162 miles removed
Neuspeed Race Springs @ unknown (came with car) & 57,054 miles removed
NGK PFR7B Spark Plugs @ 64,220 miles & 71,162 miles removed
South Bend Stage 2 Daily Clutch @ 54,275 miles & 71,162 miles removed
StopTech Performance Brake Pads Front @ 55,983 miles installed & 63,756 miles removed
