Yep//gotta ask phil why the fittings are different
Im about to do the same with the Forge plate as well..its an amazing piece
I just put my plate on an hour ago...just gotta remember the top right screw...use the shorter one for that. Wasn't too bad. I chose to choose some ultra black sealant to help the gasket a bit. Looks great. I'll check the torque on the bolts tomorrow after a few heat cycles.
The fittings are different cause racecar. lol....it is a racecan though ha.
So funny I know.
I gotta call them and see if they know a way i can make it quick disconnect. I like to take it out to empty it but honestly I have found siphon pumping it out to be the best. Even when you clock the drain plug in the best spot its still a b5tch to get something down in there to catch stuff
I noticed you went with the softer HPA mount (red). Any particular reason why? I'm thinking I may do the same now as that mount seems to be the source of most vibration depending on how it is configured.
