Old 06-25-2012, 01:27 PM   #29
BrShootr
Drives: MKVI TDI
For those who replaced speakers, I've seen 2 options mentioned: 1. cut the OEM speaker and bolt the new one to the OEM spacer; 2. Drill out the rivets and screw in a new spacer.
My questions are:
How hard is it to cut the speakers?
What size screw did you use to mount the new spacer?
Any alternative to the 2 methods I've mentioned?
Thanks for the write up and the replies!
BrShootr is offline   Reply With Quote
Old 06-28-2012, 02:49 AM   #30
dav1d
dav1d's Avatar
Drives: '10 CW DSG 2D
I know the front door speakers need spacers when swapping for aftermarkets but how about the rear panel speakers? Are spacers needed there too?
H&R cup kit - H&R 24mm RSB - APR Stage 2 - BB downpipe - Magnaflow cbe - Neupseed TOP pipe - Neuspeed pflo (red) - OEM cherry led tails
dav1d is offline   Reply With Quote
Old 06-28-2012, 05:08 PM   #31
dav1d
dav1d's Avatar
Anyone?
Old 06-29-2012, 07:46 PM   #32
glowworm238
glowworm238's Avatar
no, if you put a spacer there you wont be able to get the panel back on
ID:	22313  Click image for larger version
2010 CW DSG
Mods: APR K04, TBE, FMIC, Carbonio Stage I & II, Neuspeed TDP/ICP pipe, KW V3, APR FSB/RSB, WALK, Unibrace XB/UB, BBS RS-GT, BFI Trans/Motor Mount/Torque Insert, GTI LED Tails, P2Spec LED's, JL Amps/Stealthbox, Hertz MLk2, JBL MS-8
glowworm238 is offline   Reply With Quote
Old 06-29-2012, 07:55 PM   #33
dav1d
dav1d's Avatar
Great! Thank you
Old 11-17-2012, 08:23 AM   #34
solhaug
Drives: Golf 6 tdi
how do I remove the large black plastic access cover inside the door? I have removed the door panel but cannot remove the big black plastic cover.
solhaug is offline   Reply With Quote
Old 11-19-2012, 12:30 PM   #35
quality_sound
Drives: '13 4-door Golf TDI
That's not an access cover, it's the window regulator. It is removable but you have to first remove the window and then be VERY careful. Get a Haynes and look it through before diving in.
quality_sound is offline   Reply With Quote
Old 01-02-2013, 07:59 PM   #36
mcmike
Drives: 2010 gti mk vi shadow blue 2dr dsg
nice instructional post, i got that panel off in no time flat, only broke one clip, i have an early 2010 gti and the top torx screw was not a torx but an standard hex bolt, 8mm wrench i think, looked original, anyhow i had to pop open the panel to see what broke on my door, it was about 6 degrees out today and my driver door handle was frozen, after work it was closer to 30 degrees so i gave the handle a gentle tug and it moved alittle, so i pulled alittle more and the handle moved but the door didnt open, it appears that my mechanism inside separated, i cant get a good view inside the door with my big hands in there, but looking at parts diagrams it looks like i need a whole new assembly, i dont see how to snap it back together, bummer
mcmike is offline   Reply With Quote
Old 10-23-2013, 10:01 PM   #37
Outkasted24
Outkasted24's Avatar
Drives: 2013 CSG GTI M6
Thank You for making this thread.
it was extremely Helpful.
||| Outkasted24's CSG GTI Build Thread... |||
"I can feel their eyes on me, Wet... Like Peaches".
Outkasted24 is offline   Reply With Quote
Old 02-10-2014, 12:27 PM   #38
2013R
FIA Formula 1 Champion
2013R's Avatar
Drives: 2015 Subaru WRX
Originally Posted by 2010 UG View Post
the latch mechanism simply unclip from the panel by pulling on it
wish mine was that easy.. been looking for more detailed directions on that. i pulled in a few directions when i was doing my Focal install, and just couldnt get that handle cable off the door card.
2015 Subaru Forester XT - Satge 1
www.lasthumansgarage.com
Old 02-10-2014, 01:36 PM   #39
Outkasted24
Locate the black square plastic piece that the cable feeds into right behind the interior handle.
Grasp that black square piece, pull it back the slightest bit to release pressure on the cable, and slide it out away from the door panel and towards the actual door.
It will come unlatched, then quide the black fork looking cable track forward towards the Mirror.
Once you get it undone the first time, you'll kick yourself for struggling so hard all of those other times..
Old 02-10-2014, 01:38 PM   #40
2013R
2013R's Avatar
ill try it if i decide to remove my focal speakers. what i remember trying is pulling up on that tab thing, and it just wouldnt come off. i dont remember the square area, thats prob why i couldnt figure it out.
Old 02-10-2014, 04:42 PM   #41
beantown53
beantown53's Avatar
Drives: 2011 VW GTI Autobahn
Post
Drivers Front Door Trim - Removal and Installation
http://www.my-gti.com/1112/drivers-f...d-installation
Passengers Front Door Trim Removal and Installation
http://www.my-gti.com/1116/passenger...d-installation
Hope this helps.
beantown53 is offline   Reply With Quote
Old 02-19-2014, 10:55 AM   #42
2013R
2013R's Avatar
still havent got around to trying this removal. i have this vague feeling like the bass was better before the focal upgrade. maybe more boomy or something, giving the impression of lower bass. but, the treble was way better (cleaner) on the focal tweets. i wonder if anyone has done a mix and match with the focals, only using the tweets?
i also think the focals might eat a little power, maybe 1-2%. Reason being, they have huge capacitors/resistors that the stock speakers dont have. Those capacitors absorb some power during their function. (< mainly a guess from everything i read, i am not an electronics major. funny story though, i earned a electronics technician certificate in 1998..) Sort of like how passive component speaker sets rob more power than straight active speaker sets. Since the stock speakers are already tuned for the proper frequencies, it seems the Focals might be doubling up the frequency tuning unneccessarily.
A complicated read..
http://www.allaboutcircuits.com/vol_2/chpt_4/2.html
