Old 04-06-2014, 12:09 AM   #43
DjDistinct
DjDistinct's Avatar
Drives: 2011 GTI Mk.VI
Thanks UG! Your write-up was spot on.
DjDistinct is offline   Reply With Quote
Old 04-06-2014, 08:58 AM   #44
hotshot100
Drives: Gti Mk6
anyone have a link for the rear panel (2 door GTI) ?
K04 Club Member #79
Mart Mk6 Build Thread
hotshot100 is offline   Reply With Quote
Old 04-07-2014, 06:32 PM   #45
veedubbz7
Drives: 2013 GTI Driver's Edition
Rear door inner window slot seal removal
Does anyone know the proper way to remove the inner slot seal? This is the rubber piece with felt that sits on top of the door and seals the interior side of the window. The manual says to remove the door trim (did that), then pull up seal equally without distorting or bending. I used my plastic interior lever and wedge and for the life of me can't get it to move. I don't want to over muscle it and break something. Is there a special tool? Thanks
veedubbz7 is offline   Reply With Quote
Old 04-07-2014, 06:55 PM   #46
2013R
FIA Formula 1 Champion
2013R's Avatar
Drives: 2015 Subaru WRX
don't pull. there is a hidden screw if i remember. naw, no screws.. i was thinking of my Charger window seal.
2015 Subaru Forester XT - Satge 1
www.lasthumansgarage.com
Old 05-24-2014, 01:40 AM   #47
thegave
Drives: Golf R
Originally Posted by 2010 UG View Post
The first is that you need to make sure that the 7 little plastic rivets are are not still in the locked position, you can tell the difference by looking at these two pics I blatantly stole from someone else's write-up. The first is of the clip in a locked position (not what you want), the second is the unlocked position which is what you are shooting for.
Apparently these things have a tendency to break or get stuck in the door, I guess I was lucky. Either way its probably best to pick up a couple spares form the dealership or whatever.
I realize now that the part numbers are actually stamped on the little plastic door panel trim clip rivets, but for those who have an aversion to small text, or haven't removed the panel yet, the part number for said clips is 7L6-868-243, currently at $1.77 ea.
Another tip I learned today while I was at the dealer was that this tool will help remove the door panel without breaking any clips. You'll notice it's approximately the price of seven clip replacements, and while several have reported successful removal without breaking any, I'm sure some of you will be rather more risk adverse.
thegave is offline   Reply With Quote
Old 05-30-2014, 05:39 AM   #48
nvturbo
nvturbo's Avatar
Cheapest place for those door panel clips: clipsandfasteners.com
$9.95 for a box of 15.
P/N # 21251
....used to own a MK6 GTI
Old 06-07-2014, 02:26 AM   #49
thegave
Drives: Golf R
Nice! Maybe I'll take my panels off once a month for lulz
Old 06-07-2014, 10:39 AM   #50
Orient Express
Drives: 2010 Mk6 GTI
I got 20 clips for $12.34 HERE
Orient Express is offline   Reply With Quote
Old 06-07-2014, 10:41 AM   #51
2013R
2013R's Avatar
Originally Posted by Orient Express View Post
dang thats a killer deal. i think that would cost $35 + shipping from VW. if they are the same oem quality of course..
Old 06-07-2014, 11:26 AM   #52
Orient Express
They are OEM clips, just from VW of China.
Old 06-07-2014, 11:55 AM   #53
2013R
2013R's Avatar
wow thats a sweet price then, except for the fact that delivery takes 2 weeks or more. if i didnt already have 5 spares i might have ordered some.
Old 07-06-2014, 07:54 PM   #54
saman
Drives: 2011 VW GTI Autobahn
the first is that you need to make sure that the 7 little plastic rivets are are not still in the locked position, you can tell the difference by looking at these two pics I blatantly stole from someone else's write-up. The first is of the clip in a locked position (not what you want), the second is the unlocked position which is what you are shooting for.
So when it's in locked position, is there any way to unlock it and use it or you have to buy new ones?
saman is offline   Reply With Quote
Old 11-19-2014, 12:21 PM   #55
koolgreen
koolgreen's Avatar
Drives: 2011 CSG 6mt detroits
my door latch is freezing below -5 deg C..... It has been lubed by the dealer externally and does not help.
Anyone had similar problem?
I am thinking the cable that connects the door handle to the latch is seized and does not move freely.
there is absolutely no issues in warm weather or even cold weather until it goes below -5 deg C.....ie 20 deg F......
koolgreen is offline   Reply With Quote
Old 12-14-2014, 05:59 PM   #56
engineered2win
engineered2win's Avatar
Drives: Subaru WRX, Multistrada DVT
If you don't have panel pliers, I found that shoving two of those plastic panel pry bars between the flange that mounts to the door panel and the plastic locking tabs will get them to unlock. I only broke 1/7 (the white plastic cap cracked and fell off) using this method, but had spares on hand.
engineered2win is offline   Reply With Quote
