djphoenix18
Do any of you guys get a weird vibration on the brake pedal when turning on your car after install??? Also, whats with the Thomas the Tank whistle when im hitting vtak?? Thx
the vibration means you have it installed on the brake reservoir. you need to reinstall it while holding it up and away from the resevoir while you tighten it down.Do any of you guys get a weird vibration on the brake pedal when turning on your car after install??? Also, whats with the Thomas the Tank whistle when im hitting vtak?? Thx
not that im aware of you will just continue to get vibrations in your brake pedalWill it harm anything if I leave it like it is?? And thanks for your response!
