Old 01-09-2015, 01:53 PM   #29
Jerseynoob
Rally Car Newbie
Drives: 2010 Jetta Wolfsburg
Originally Posted by 2013R View Post
i ran that setup also. worked great for the short time i used it. made my blow-off sound crisper and faster when i added the relocation kit.
just wondering, why did you remove it?
Jerseynoob is offline   Reply With Quote
Old 01-09-2015, 01:56 PM   #30
Jerseynoob
Rally Car Newbie
I've got the Uni DV relocate, then got the DV+ part, been running it since this past summer, haven't really notice any difference. But it's too cold for me to do any tinkering on my car, so it'll say on at least until it's warm, or shit's the bed for some reason.
Old 01-09-2015, 01:56 PM   #31
2013R
FIA Formula 1 Champion
2013R's Avatar
Drives: 2015 Subaru WRX
because im plac.
2015 Subaru WRX - Stage 2+ w E85
2015 Subaru Forester XT - Satge 1
www.lasthumansgarage.com
2013R is offline   Reply With Quote
Old 01-09-2015, 04:22 PM   #32
Jerseynoob
Rally Car Newbie
because im plac.
Old 01-09-2015, 04:31 PM   #33
WetMoney
WetMoney's Avatar
Drives: "Love the Cars, Hate the Scene"
because im plac.
BOO-YAH!
Unitronic K04 Stage 2+ | Neuspeed FMIC | Unitronic Intake | CTS DP w/AWE CB | BC Racing BR Series Coilovers | H&R 24mm RSB | HPA 75A mount | South Bend Drop-in | more...
WetMoney is offline   Reply With Quote
Old 01-10-2015, 02:58 AM   #34
corrado917
Formula 3000 Driver
corrado917's Avatar
Drives: GTI CSG
Originally Posted by U-20T View Post
Its not "for no apparent reason" its because it does not operate like a true dv valve with the extra spring nor as intended.
You want your dv to react as fast as possible with the way the dv+ with the spring its not the case. It relies on boost to physically open thus its slow (its like no hooking up vacuum lines to a pneumatic dv in a sense or putting to heavy springs in it). Then because of that 100% of excess does not pass through it. Both situations is why there is a DV in the first place....
Somebody posted some logs about the DV+, that reacts faster at low RPM while the OEM DV is faster at high RPM, wonder now if that deficiency at low RPM is actually cured with the Uni Relocation kit...?
Originally Posted by rupertpupkin View Post
See my review.
http://www.golfmk6.com/forums/showth...62#post2113362
All i know is of my 3 setups, the DV+ made the car run the worst. Now I am a stage 2 Uni Golf R and FSI, but just saying what my findings were on my specific car. Really well made nice piece, but made my car suck. Very odd that the BOV on mine is the best feeling setup.
Awesome video, my car sounds just like that with the OEM DV.
A buch of goodies APRís K04 kit, NGK 8 plugs , Unitronic Intake, Eurojet DP, Magnaflow catback, APRís TCU tune, 034 Dogbone Mount Insert, S3 intercooler, Forge catch can, Modshack trim, AWE tuning IC hoses, Neuspeed K04 TOP & TDP, H&R Cup kit, Golf Rís skirts & side mirrors, Euro LED tails, GTD grill, H&R sways, Stern bar, Enkei RPF1 & some other stuff..Build
corrado917 is offline   Reply With Quote
Old 01-10-2015, 07:48 AM   #35
U-20T
Formula 3000 Champion
Drives: BT GTI4Motion
What were they logging to make that call? I doubt vcds is even fast enough one and two if they logged dv duty cycle its controlled by the ecu and its litterly a log of what the ecu tells it to do so the would not show it being faster or not. If there was a true position sensor like some was gates and I believe synapse if coming out with a position sensor on their dv/bovs then it could show what its doing but we don't have those sensors.
U-20T is offline   Reply With Quote
Old 01-10-2015, 01:13 PM   #36
2013R
2013R's Avatar
Somebody posted some logs about the DV+, that reacts faster at low RPM while the OEM DV is faster at high RPM]
I think having boost come on 200-300 rpm sooner is more valuable than top end gear change response for most people. My personal logs showed this boost coming on sooner. That is why at least half of the forum regulars run this.
Old 01-10-2015, 05:09 PM   #37
corrado917
Formula 3000 Driver
corrado917's Avatar
Drives: GTI CSG
Got it.
It all depends, I rather have the last word at high end, now my attention is towards to keep the OEM DV and eventually consider just the Uni relo kit to compensate the real issue (at least what they claim), without making another one: Low RPM.
Old 01-10-2015, 08:18 PM   #38
mk6'12gti
Drives: 2012 4dr Black Gti
before i went back to the rev d dv an the gfb dv+ i had a forge dv an there spacer on the unitronic relocation kit.. never had a problem besides when shifting there was a delay so i got rid of the forge set up an went with the rev d an gfb the difference was night an day barely any lag in between shifts an throttle response was way better. so far i cant compain using this set up with unis relocation kit
| Apr Ko4 v3.2 | Apr stage 2 Dsg | Do88 Ic | IE intake | Circuitwerks turboback | Ecs street shield | R8 coils | S3 style top | Spulen throttle pipe | BC coils | Uni dv relocate | 034 street density mounts | 034 pendulum mount | Hpa 75A puck | P3 Gauge | GFB Dv+ | Apr catch can | Osram headlights |
mk6'12gti is online now   Reply With Quote
Old 01-10-2015, 08:40 PM   #39
vwgti2.0t
Drives: 2011 CW GTI
No no. Everyone get a snapsys mechanical valve.. And add a bunch of sensors to it so you can log it being slower than stock..
vwgti2.0t is offline   Reply With Quote
