GMP Performance
Hey guys, we've got a ton of the TSI Intakes on the shelf and we're trying to move them, so we're giving you FREE SHIPPING within the US!!
Feel free to contact us if you have any questions or would like to place an order!
:w00t::w00t:
Carbonio's latest carbon fiber intake for the 2.0 TSI engine is a truly race engineered ram air design that is available for the first time as an affordable street car intake system. Building from years of experience on and off the race track, Carbonio's and APR's engineering teams have spent countless hours developing a true cold air and ram air carbon fiber design that can be recreated affordably for the street performance enthusiast.
Carbonio and APR have gone even further to maintain all oem specifications necessary to integrate cohesively with an otherwise stock engine to avoid raising eyebrows at the dealership. Flexibility was another characteristic of Carbonio's and APR's design whereas the new TSI intake is also suitable for Stage 1 and Stage 2 modified engines all the way up to and beyond APR's Stage 3 Turbocharger System.
Ram air induction is accomplished by maintaining the oem air inlet opening at the front of the leading hood edge which is the highest pressure area of airflow across the entire vehicle. Placement of the air filter as close to this high pressure zone as possible results in overcoming some of the airflow restriction created by even the highest flow air filters available.
Cold air induction is accomplished by completely sealing the intake system from the hot engine bay air and then taking it even further through the choice of Carbon Fiber material and an additional thermal barrier application to the inside of the intake system. Quite often intakes are advertised as cold air induction even though the material choice is a metal or plastic composite which simply does not insulate the incoming air from the hot engine bay air or does not completely seal the intake system in the engine bay allowing hot air to enter the intake stream negating any cold air induction gains.
Benefits of the Carbonio CAI System include:
-Increased Horsepower and Torque
-Improved Throttle Response
-Decreased Turbo 'Lag'
-Flattened Torque Curve (engine is less 'peaky')
-Improved Fuel Economy
-Enhanced Engine Volumetric Efficiency
-Enhanced Sound of Turbo Diverter Valve
-Installs in an Hour (does not require bumper or headlight removal)
-Maintains Clean Appearance by Retaining Factory Engine Cover
-Maintains All Factory Emissions Components
-Fits Both Manual and Automatic Transmissions
-Unique Thermal Barrier Composite Construction Ensures Low Inlet Temperatures
-Fully Compatible and Complimentary with APR Software and Exhaust systems
Each Carbonio Kit Includes:
-High-Flow Air Filter
-Aerospace Grade Carbon Fiber Main Section
-Show Quality Finish
-Complete Photographic Instructions
-All Necessary Hardware Included for Easy Install without Cutting Or Modifying
Optional Components:
Breather Host Filter - Required for CBFA engine codes
Ram Air Bracketry - Required for the Passat/CC/Tiguan
http://gmpperformance.com/index.cfm?PG=detail&PID=202322
:w00t::w00t:
