Hi guys, sorry to sound like a noob but I'm doing my first timing chain on this engine and have done timing belts on civics and a 2001 jetta once. I just want to confirm that I'm doing the job correctly.
I messed up taking apart the timing chain assembly and the chain has jumped and all that stuff. i want to properly time the engine and make sure that i don't bend valves when starting the engine.
So i have the camshafts lined up and have the crankshaft at TDC, the arrow is pointing at 12 o clock on the camshaft sprocket. but I'm wondering how to match up the blue link on the sprocket. i don't see any marks other than the TDC mark. am i supposed to line up the blue link to the TCD mark somehow which doesn't seem possible or just set at TDC (12 o clock) and just put the chain as is without any marks indicating that blue link since the piston is at TDC?
Thanks again and sorry for sounding like a noob. This is my first owned VW and want to make sure i do everything to the book.
Reason I'm asking is because the MK6 GTI i bought had a P0016. I have a new tensioner (K Suffix) and want to make sure everything is good. Engine has a 140k on it. should i also change the Timing Chain?
