Post your sub setups!
StayStetti
Banned
Subs or speakers..Specs too!
Kenwood KAC-9105D Mono class D, 1800 watt peak, 900RMSx2 @ 2ohms. The lights go perfect with the interior.
2 Kicker CompVR's, 400RMS.
Cheap Fierce audio sealed box. (got it for $20).
Stock speakers.
YellowC4S
Factory RNS-315
Audison BitOne
Zuki 4ch Eleets
Zuki 5ch Hybrid
Hertz MLK2 TW front/rear
RE Audio SEX-104
trd420
Lanzar VCTBS10 800 Watts Max 10-Inch Super Slim Active Subwoofer in hach
specs
10'' Slim woofer - Phase shift switch: 0 or 180° - Thermal, short and overload protection circuits - Slim woofer: 250Watt
RCA low level input - Adjustable input sensitivity: 0.2V-3V - Fuse: 2x20A - Dimension: 15'' X11.8'' X 3''
High level input - 0 to +12dB variable Bass Boost (@45Hz) - Max power: 800 watt - Weight: 15.5 LBS.
Green & red LED power status indicator - Low pass filter (50-150 Hz) - RMS Power:
Remote level control - Soft delay remote turn-on - Amplifier: 100Watt
swervinVI
Stock Dynaudio system
JL 10w6v2 sub in a stealthbox
JL JX500/1D amp
JL Audio XB-MFBU-ANL Master Fuse Block
Scosche Loc80 2-Channel Adjustable Lineout Converter
Rockford Fosgate RFK4I - 4 Gauge Power and Signal Installation Kit
swfloridamk6
Stock headunit feed into Memphis signal processor w/bass adjustment
2 JL 10W6V2 subs
4 JL C5 separates
MCC204 - McIntosh 4/3/2 Ch 200 Watt
MCC302 - McIntosh 2 Ch 600 Watt
Stinger 2nd battery
CandyMan11
JL JX500/1D amp
:w00t:I love it! so clean and still get the usable trunk space. How much Does a setup like that cost you??
swervinVI
It was around $1100 for the sub/box, amp, installation kit, LOC and fuse block. My boyfriend did the installation, so I saved some there.
mcgti6
Pioneer premier head unit
JL audio front 6.5's, front & rear tweeters
Alpine rear 6.5's
JL audio 10w7 in a sealed box
Hifonics 600w 2 channel amp (gettin more around 550w)
no amp for the components yet, but everything still sounds 10x better than stock
E-Rocko
Base, RCD-310
SOT-976 harness
AudioControl LC2i, under the passenger seat
Rockford Fosgate T400-2, bridged, at 800RMSx1 @ 2-ohms, under the driver's seat
Eclipse SW9122 Titanium DVC 12" sub, RMS: 750 watts, Peak: 1500 watts, in a Sonic Electronix 1.158 cubic ft. box
Scosche EFX 4-gauge Amplifier Wiring Kit
Goobax
RCD 510
Alpine Type R 6.5 components front and rear
Alpine Type R 10in
Alpine PDXM6
Audio control LC6i
Need to put the components on an amp one of these days and get a RNS315
