Selling my 2011 GTI if anyone is interested:
For sale APR Stage III VW GTI 2011 2-door with over $18 thousand spent on mods. The car is only 6 months old. Pristine condition, no accidents, never taken on track. Fully loaded with every package available, which includes sunroof, gps, 30 gig hard drive, leather/heated seats. For more info on packages visit vw.ca
List of mods:
APR Stage III ECU flash with 4 programs(stock,91,93,valet)
APR Transverse Stage III turbo kit (gt28rs turbo)
APR DxD Stage III clutch kit (with single mass flywheel)
APR Carbonio Cold Air Intake Stage I (stage 2 pipe is not needed with Stage III turbo upgrade but is included ($200 value)
Billy Boat turboback exhaust system
Neuspeed torque arm insert
Labonte water/methanol system
4x OZ Allegeritta 18x8 low weight wheels with 225/40/18 conti extreme contact dw with more than 90% thread left
European OEM GTI LED headlights
Spyder LED tail lights
Anti-Corrosion module
APR Crest Vinyl (can be taken off)
20% tint all around (can be taken off)
The car had 262.7 whp at Stage II(dynapack), which is beyond APR's advertised #s. At stage III, with water/methanol on 93 program you can expect at least 330 whp(I haven't dyno'd it). Stock 2011 GTI is around 180whp (200 crank). Oil changes has been performed at the dealerships every 7k kms(8k is advised). The only fault that was ever found on the car was the power window switch acting up(replaced under warranty). No rattles, no bad noises - only turbo spooling and intake sucking in the air. Stage 3 has been on for 5k kms. The amount of money spent on mods is beyond $18k(have receipts to show). The car has been babied and broken-in properly. Never seen anything except 94 octane from Petro Canada.
The car also includes: 4x detroit wheels (stock) 18x7.5 on perelli pzero nero 225/40/18 all season (70%+ thread left)
K03 turbo in case you want to downgrade - 10/10 condition
APR Carbonio Stage II pipe
Dual mass factory flywheel
Vag-com cable+software to learn/tweak things on the car and know exactly what's at fault without spending $100 for diagnostics at the stealership.
Factory Warranty + Free Towing for the remainder of 4 years.
Looking for something around $38,000
