HYDE161
it's a cop out. they should know it's not needed for the car to run properly.
Do you use your N75 for boost control or do you leave it plugged in electronically (not plumbed)?
If you're N75 is already plugged in (to avoid codes) but not plumbed (because you use the Greddy Project EBC), what do they mean by adding it back in? Run it instead of the Greddy? You can't have both plumbed in controlling boost.
thats what im figuring. Sent in the logs for when its happens last night. well see whats up
it's only plugged in. when it was unplugged, the car wouldn't build boost at all. when i plugged it in it started building boost again, and since my file is always requesting 2550mbar at WOT i've never had an issue controlling boost with the aftermarket controller.
post it here
there are 4 different sets they wanted. ill have to go into each and screenshot and block out when the issue happens. i should be able to this afternoon
post it here
interested in this for sure.
Why do you have to block anything out? Can't you just post the Excel log file?
Upload them to Dropbox or Google drivewont let me add them as attachments
Put the N75 back, no weird surging issues down low anymore. Enjoying this Turbosmart DV now too.
That's the trade off, unfortunately. Not to mention you won't have to adjust boost every time the weather changes, which in CT is 40F at night and 80F during the day.. so it'd get annoying quick loli like changing my boost level too much. that's why i switch to a 10psi spring so i can set up the boost by gear and run low/high boost on the fly with the cortex ebc. that's disappointing to hear if that's all it takes my partial throttle response has always been iffy.
