Old 09-25-2013, 07:17 PM   #85
mathieu92
Oval Newbie
mathieu92's Avatar
Drives: 2011 GTI
To follow up on the FX400 failure, my car went in the shop on Monday.
Engagement point was really high which seemed to indicate that the clutch disc was worn. They did pull it out, and it indeed was worn out.
Clutch was shipped to clutchmaster, who received it today. They invoked the normal wear and tear, the out of warranty and the fact that the FX400 should be used for racing mostly.
Like many others here, they proposed to rebuild it for a decent price, even with the above mentionned comments.
Overall they have been very nice and arranging.
I am still out of pocket on the labor cost and the temporary rental car cost.
So I will get it rebuilt to FX350, with a stronger pressure plate, and get it back in the car asap, crossing my fingers that it lasts longer.
If you are considering a new clutch for a mostly street driven car, you should look at the 350 more than at the 400...
2011 Mk6 Autocross sleeper -> Sold
mathieu92 is offline   Reply With Quote
Old 11-07-2013, 02:41 AM   #86
BIG FAT UNCLE PAULY
Rally Car Newbie
BIG FAT UNCLE PAULY's Avatar
Drives: SOLD-2011 2dr mt cw GTI
Bought the Clutch Master FX400 8 PUCK 17375-hdcl-shp last December and had it installed at 20K miles. 9K+ miles later, needed to replace as it was slipping in 2nd and 3rd in stock mode.
Read more : http://www.golfmk6.com/forums/showth...35#post1448135
"HOW YOU GOING TO FIT IN THAT LITTLE CAR UNCLE PAULY?"
APR stage 2 ecu, APR Carbonio stage 1+2 intake, UR downpipe, Borla catback, S3 intercooler, AWE turbo outlet pipe, HST RSR clutch, Neuspeed short shifter, NSP boost gauge, BFI stage 2 torque arm insert, Hotchkis 27mm front/rear swaybars, Koni Sport struts/shocks, VW Driver Gear springs, Stoptech pads, Tyrol Sport caliper bushings, Neuspeed RS12 wheels, Mich. PSS.
BIG FAT UNCLE PAULY is offline   Reply With Quote
Old 12-02-2014, 03:56 PM   #87
mathieu92
Oval Newbie
mathieu92's Avatar
Drives: 2011 GTI
Holy thread revival batman!
My rebuilt FX350 is starting to go out...
What is the consensus on clutch solutions nowadays? I could get it rebuilt again, but wonder if there are any better solutions.
Anybody moved away from clutchmaster? what did you go with? How is it holding (how many miles on it?)?
Old 12-02-2014, 05:19 PM   #88
toxicfusion
Banned
Drives: 2013 GLI Autobahn
Go with HS Tuning RSR clutch kit. Or look at thread Calklin started on what parts you can source to build your own 'RSR' kit using Audi TT-RS or TT-S pressure plate.
toxicfusion is offline   Reply With Quote
Old 12-02-2014, 06:48 PM   #89
XGC75
Formula 1 Driver
XGC75's Avatar
Drives: into shit
I'm now at 35k miles with the RSR. Hasn't changed a bit since break-in.
butchered by autocorrecr
XGC75 is offline   Reply With Quote
Old 12-02-2014, 08:17 PM   #90
Mike@Ringerracing.com
Rally Car Newbie
Drives: 650awhp B5 A4 1.8t
If you end up wanting to rebuild your FX350 but with my Stage 3 full face disk or Stage 4 full face disk instead let me know and I can see what type of price I can work out for you.
This is my stage 3 disk
My Stage 4 disk
Mike@Ringerracing.com is offline   Reply With Quote
Old 12-02-2014, 10:31 PM   #91
Mustache rash
Formula 5000 Champion
Mustache rash's Avatar
Drives: 2011 K04 GTI 6mt
My Stage 4 disk
Can you do the same for southbend?
2011 CSG GTI 6MT
APR K04 3.1
Build Thread
IG@mustache_rash
Mustache rash is offline   Reply With Quote
Old 12-02-2014, 11:23 PM   #92
smrtypants44
smrtypants44's Avatar
Drives: 2012 135i
Yeah my rebuilt fx350 is going too... if anyone is keeping track thats 9k on the 400, 15k on the 350. I'm going to buy a rsr kit and a oem dmf and try and get my oem feel back.
smrtypants44 is offline   Reply With Quote
Old 12-03-2014, 02:14 AM   #93
jerome99
jerome99's Avatar
Drives: 2011 GTI
My fx 350 is slipping after 30k mostly highway miles
Sent from my VS985 4G using Tapatalk
2011 GTI Build Thread
K04, Godspeed DP, Godspeed IC, CM FX-350 w/DMFW, H&R Coilovers, Boxter-S BBK,
jerome99 is offline   Reply With Quote
Old 12-03-2014, 10:25 AM   #94
Rally Car Newbie
No I can't have South Bend kits rebuild with my disk, I can with the CM kits since CM is who builds my private label kits.
Old 12-10-2014, 05:47 PM   #95
mathieu92
Oval Newbie
mathieu92's Avatar
Drives: 2011 GTI
Thanks for the proposal Mike.
Unfortunately, I am moving away from the entire CM assembly. I am now considering either putting my OEM stock clutch back in (and put the entire car back to stock to sell it - potential big part out in that case!!), or the RSR kit and keep the car another couple of years.
