Old 07-26-2017, 04:59 PM   #1
Mk62013
Drives: 2013 MK6 gti apr tuned '
Dg springs help !
My Dg springs ride really harsh. It feels like the shocks aren't even doing there job and the car smacks the bumps very hard. Sometimes the wipers go on. The right front side is the biggest problem. I checked the endlinks and other stuff and everything looks good. Any ideas ???
Mk62013 is offline   Reply With Quote
Old 07-26-2017, 05:00 PM   #2
Jaber
Modero
Jaber's Avatar
How many miles on your struts?
Member Journal
Old 07-26-2017, 08:47 PM   #3
Mk62013
12k miles
Old 07-26-2017, 10:20 PM   #4
DarianBx3
DarianBx3's Avatar
Drives: 2013 MK6 GTI DSG
I am in the same boat as you. In Houston it’s BAD. Only suspension stuff I have is the DG springs and sways.
APR Stage II Build Thread
DarianBx3 is offline   Reply With Quote
Old 07-26-2017, 11:41 PM   #5
Mk62013
If anyone can chime in that would be great
Old 07-26-2017, 11:42 PM   #6
Mk62013
@DarianBx3 Wow someone with the same problem as me . Hopefully we can figure this out.
Old 07-27-2017, 03:21 AM   #7
Laimface
Laimface's Avatar
Bilstein B8 shocks.
Old 07-27-2017, 06:40 PM   #8
BIG FAT UNCLE PAULY
BIG FAT UNCLE PAULY's Avatar
Drives: SOLD-2011 2dr mt cw GTI
You need to upgrade the shocks & struts.
I went with Koni Sport shocks / struts but if you have some extra $$$ look at Bilstein
http://www.bilstein.de/de/produkte/b...clubsport.html
"HOW YOU GOING TO FIT IN THAT LITTLE CAR UNCLE PAULY?"
APR stage 2 ecu, APR Carbonio stage 1+2 intake, UR downpipe, Borla catback, S3 intercooler, AWE turbo outlet pipe, HST RSR clutch, Neuspeed short shifter, NSP boost gauge, BFI stage 2 torque arm insert, Hotchkis 27mm front/rear swaybars, Koni Sport struts/shocks, VW Driver Gear springs, Stoptech pads, Tyrol Sport caliper bushings, Neuspeed RS12 wheels, Mich. PSS.
BIG FAT UNCLE PAULY is offline   Reply With Quote
Old 07-27-2017, 09:49 PM   #9
DSGVW
DSGVW's Avatar
Drives: 2012 CSG GTI DSG
12k miles? Sounds like the roads are just garbage and the 18" low profiles are harsh. I'd upgrade the shocks for good measure but 17s will probably help you more.
Old 07-27-2017, 10:02 PM   #10
thzpcs
Drives: 2010 BMP GTI
Why would you need to? The DG springs are specifically designed for the OE struts and shocks, and his are almost brand new.
thzpcs is offline   Reply With Quote
Old 07-28-2017, 03:00 AM   #11
snobrdrdan
Formula 2 Champion
snobrdrdan's Avatar
Drives: a VW
For the GOLF, not the GTI
If you're happy with the ride height of the DG's, then I'd upgrade the dampers if the stock ones aren't cutting it for you...there will be a difference
2017 Passat VR6
2017 Passat R-line
Old 07-28-2017, 09:48 AM   #12
BIG FAT UNCLE PAULY
Because the OP states he's not happy with the harsh ride.
