Old 09-08-2017, 02:28 PM   #1
FlavMK6
FlavMK6's Avatar
Drives: MK6
New oil pan? Or drain plug?
I'm new to MK6 family' I bought a 2012.
I went to get an oil change and he mechanic told me that there's some leaking going on.... Got under the car and this is what I found'. It's leaking from the plug it self' and it had a little rust around it, also realized that the plug is not factory I think' what should I do? Change just the plug and washers? Or at this point buy the whole pan? Thanks. I'll post a video of it
FlavMK6 is offline   Reply With Quote
Old 09-08-2017, 02:59 PM   #2
lilonespaz
Formula 2 Driver
lilonespaz's Avatar
get a oem plug and washer.
Old 09-08-2017, 03:05 PM   #3
1ashchuckton
1ashchuckton's Avatar
Drives: 2013 GTI Carbon Steel Grey DSG
Like has been said, get an oem plug & crush washer. Hopefully that will take care of you. If the threads are buggered up then it's new pan time. I'd guess the oem plug & crush washer should fix you up.
Old 09-09-2017, 10:47 AM   #4
FlavMK6
FlavMK6's Avatar
Drives: MK6
Originally Posted by 1ashchuckton View Post
Like has been said, get an oem plug & crush washer. Hopefully that will take care of you. If the treads are buggered up then it's new pan time. I'd guess the oem plug & crush washer should fix you up.
Thanks!! I will try and change it today and see how it goes.
Old 09-13-2017, 08:53 AM   #5
lilonespaz
Formula 2 Driver
lilonespaz's Avatar
how did it go for you?
Old 09-13-2017, 09:48 AM   #6
thedude4bides
Formula 1 Driver
thedude4bides's Avatar
Drives: '12 Golf R
Who was changing your oil? Were they re-using the plug? You should always replace the plug as it's really one time use.
I am the only one who changes my oil after a shop screwed up my threads and I needed a new oil pan.
thedude4bides is offline   Reply With Quote
Old 09-13-2017, 11:31 AM   #7
1ashchuckton
The plug is not a one time use, but the crush washer sure is. Lots of oil change places don't replace the crush washer. Plus many screw up the threads & then jamb a self tapping plug in there to cover their mistake. That's why I always do my own oil changes.
My local dealer does topside oil changes, but I still do it myself.
Old 09-13-2017, 04:01 PM   #8
lilonespaz
Formula 2 Driver
lilonespaz's Avatar
most of the time the crush washer wont come off the old plug so you need to replace the plug too. lol If it was properly crushed.
Old 09-14-2017, 12:41 PM   #9
1ashchuckton
If one can't remove the crush washer from a drain plug they should hang up their wrenches. The first oil change is hard due to the washer & plug being held together with paint. After that it's a snap.
Old 09-14-2017, 01:28 PM   #10
lilonespaz
Formula 2 Driver
lilonespaz's Avatar
dunno what you are talking about or im just too strong(using a torque wrench) but my crush washer was literally not able to pass by the threads after it was crushed/used... I had to snip at it with tin snips for a bit to get the old one off to be able to even use the bolt again as i had not bought another bolt only a new washer.
They call them CRUSH washers for a reason, as in the crush and spread out a tiny bit to make a seal..
Old 09-14-2017, 02:55 PM   #11
1ashchuckton
Guess we'll both be confused. Never had one get stuck on.
Old 09-14-2017, 03:25 PM   #12
lilonespaz
Formula 2 Driver
lilonespaz's Avatar
yeah not sure it surprised me too but i never checked the others because all the other oil change kits i bought came with a new bolt... i bough this other one as separate parts and left off the plug.
Old 09-18-2017, 12:14 PM   #13
nvturbo
Formula 2 Driver
nvturbo's Avatar
Drives: 2012 VW VERSA hatchback
Make sure the drain plug is torqued properly. Don't ask me how I know.
....used to own a MK6 GTI
nvturbo is offline   Reply With Quote
Old 09-18-2017, 01:38 PM   #14
aj_law
FIA GT Champion
aj_law's Avatar
Drives: 2012 Tornado Red 4DR 6MT GTI
IMO, if you're torquing the oil drain plug so much that the crush washer can't be removed from the bolt, you're using the wrong spec or just going at it too hard.
I know what you mean about the crush washer being crushed and spreading though...every time I've done mine, it is a little tough to take it off the bolt, but I've never had to cut it; usually just work it around a few threads with minimal effort.
To the OP, as has been suggested multiple times already, I'd obviously start with an OEM bolt and washer and go from there.
('12 4DR/TR/6MT GTI - MEMBER OF THE 125K+ MILE CLUB) WISHLIST (bolded done...lol): Performance - Unitronic Stage 1 & CAI // Unibrace UB // DG springs // H&R 26FSB/22RSB // Tyrolsport Subframe Kit ||| Cosmetic - OZ Leggera HLT // Color matched markers/lip // Black emblems/grille stripes // OEM R Tinted LED tails // Raceseng Ashiko shift knob // 30% tint // Soundaktor delete
aj_law is offline   Reply With Quote
