Thumper
I can get everything except the opening of the sunroof slider...I can get it to close with the windows...just not open... thoughts?
Opening feature on the sunroof does not work. That's probably why.
Question. Just switched out brake pads to those that do not have wear indicators. Is there a setting that can turn off both the brake warning and the "brake" light?
I don't think it's mechanical. I believe it's just built into the ABS controller. Maybe it's different in the UK though. I'd just try turning it on and seeing if it works. :iono:
Cool. Now a dumb question: How does Hill Assist work? Does it have to be in gear or will it auto kick in when I release the handbrake on a hill?Try it - the worst that could happen is that it doesn't work.
My advice is to enable it, save the settings, turn on the car and try to scan your ABS module to see if any faults come up. Then you can go out and try to see if it works
Thanks
P.S when I take my car back to VW for any work will they know I've changed all these codes and reset them? Has this happened to anybody before?
I have taken my car in numerous times for warranty work, no codes were reset, nor any mention of my imense amount of vag-com tweaks
Good to hear, lads.
>EDIT< Sorry for all the Qs, another...
If I ask the Vag-com guy to turn off the Bulb Out warning light due to exterior LEDs, will it still come back on if I have a bulb out later on?
You're only "turning off" the error for the rear lights, because you're changing the code to match your lights. The existing errors are then cleared out. If you have some other bulb go out you'll still get a light. As for the rears, I don't known if you'll get a light in the future.
