Mike@Forge
Comparing the two different 200 hp engine versions, yes, you are mostly correct.
The Golf R engine is based on the older "FSI" engine, but still has upgrades over the 200 hp K03 version.
-TSI has an updated PCV system
-TSI has a gear type timing chain (vs belt)
-TSI has updated high pressure fuel pump/cam lobe design
-TSI has a non-timing belt/chain driven water pump (vs timing belt driven)
-TSI has a one piece intake manifold and flap setup (vs separate flap motor)
-TSI has a vacuum controlled intake flap (vs electronic)
-TSI has an IHI manufactured K03 turbo (vs. manufactured by Borg Warner) exact same spec. to FSI K03
