Old 05-18-2017, 01:19 PM   #1
pdan
pdan's Avatar
Drives: 2009 VW Jetta TDI (sold), 2013 GTI
No oil pan bolt??
Hey guys, I figured I'd check with someone before I did something stupid. Going to change the oil today, and saw it was a 19mm bolt online that needed to come out to change to oil. Go down, and where I thought the bolt is there was this
So am I being completely dumb and just missing something, sorry this is my first actual oil change ha.
pdan is offline   Reply With Quote
Old 05-18-2017, 01:29 PM   #2
ZiggyMKVI
ZiggyMKVI's Avatar
Drives: 2010 Black GTI
Looks like someone decided to put in a different style bolt. Where did you get the oil changed before?
2010 GTI _ mods: Magnaflow-Catback, DG short shifter, BSH catch can, Neuspeed Throttle body and Discharge Pipe, ESC intake, R8 Coilpacks, Forge Motosports coilovers, Rotiform TMB 18 x 8.5, SPM Catless DP, Stage 2 Unitronic, ARM front mount
IG: Scottziggs
ZiggyMKVI is offline   Reply With Quote
Old 05-18-2017, 01:33 PM   #3
pdan
pdan's Avatar
This is the first time I've changed the oil, I bought it CPO back in November. So that is definitely where the oil pan bolt should go, now I just have to find something that will fit it I guess.
Old 05-18-2017, 01:51 PM   #4
1ashchuckton
1ashchuckton's Avatar
Drives: 2013 GTI Carbon Steel Grey DSG
That is the oem bolt. My 2013 has one of those. When I went to the dealer for some crush washers I asked the parts man about that bolt. He handed me the exact same one & said it was normal.
Make sure to replace the crush washer otherwise you'll have a drip.
It's a T45 Torx bit. I bought a nice set at NAPA.
Old 05-18-2017, 02:05 PM   #5
ZiggyMKVI
ZiggyMKVI's Avatar
Ah my 2010 has a hex head bolt, not one like that. I have since gone to a ecs magnetic drain plug tho.
IG: Scottziggs
Old 05-18-2017, 02:24 PM   #6
pdan
pdan's Avatar
Ahhh thanks a bunch. I too have an ecs plug I'll be replacing it with. On the way to get yet another torx bit ha
Old 05-18-2017, 02:41 PM   #7
notovicrious
notovicrious's Avatar
Drives: 2011 GTi 2.0T
It is a bolt but not the hex bolt you probably imagined. This is a T45 torx head. I think the mk5 is a hex I'm not positive on that. Either way if you own and do work on a mk6 a fine torx set is a must have along with a "triple square" set. Just be careful not to confuse torx with Allen as you may get it the first time but will eventually strip this head using the wrong tool. Good luck and don't be afraid to ask us all for questions bro!
Old 05-18-2017, 10:43 PM   #8
FocalPoint
Formula 3000 Champion
FocalPoint's Avatar
Drives: MKV GTI/MKVI GTI
Had this one my new long block after my old one took a shit. I was just as confused. It works fine though, and I never replaced the crush washer and have had zero leaks since.
FocalPoint is offline   Reply With Quote
Old 05-18-2017, 11:33 PM   #9
ithrashmotors
FIA World Rally Car Newbie
ithrashmotors's Avatar
Drives: Mk6 gti
I prefer the t45 over the hex plug.
APR stage 1//Carbonio intake//R8 coilpacks//GFB DV+
ithrashmotors is offline   Reply With Quote
Old 05-19-2017, 02:22 AM   #10
BudgetPhoenix
Drives: 09 GLI
My 09 had that bolt, but I ordered a new one and it appears it was superseded with the 19mm hex one.
Old 05-19-2017, 11:59 AM   #11
notovicrious
Same.
Old 05-21-2017, 12:08 PM   #12
pdan
pdan's Avatar
Soooooo went and bought a t45 and big surprise it doesn't fit. It's slightly too large. Does anyone know of a standard bolt that they would have used instead, otherwise I'm just gonna go out and try and buy a whole set
Old 05-21-2017, 12:58 PM   #13
1ashchuckton
It's rather odd that a T45 doesn't fit yours. I just went out in the garage & checked again & yes it's a T45. The one in my pan was removed & reinstalled with the T45 & the spare on the garage shelf is also a T45. I'm at a real loss to explain why your T45 does not fit.
Old 05-21-2017, 01:37 PM   #14
pdan
pdan's Avatar
So I have no idea why a t45 didn't really fit, but a t40 was too small. So what I ended up doing (for better or worse) was taking a hammer and I managed to hammer the torx into the bolt lol. It went in and I was able to get it out.
I have no idea why it didn't want to go in, there didn't seem to be any deposits or anything on the bolt head. Anyway got it out, changed the oil and replaced it with an ecs tuning drainplug, I feel a lot better now ha.
Thanks everyone for the help, should go much smoother next time
