Old 08-29-2016, 05:38 PM   #6077
DASVDUB
DASVDUB's Avatar
Originally Posted by SirClimax View Post
I had Super Sports with Koni Yellows which are much stiffer and big bumps can be jarring but it eliminates the bouncing that people often get with stock shocks and lowering springs.
The yellows are stiffer? Thought they were the same as oranges except you can adjust how stiff it is.
Old 08-29-2016, 05:58 PM   #6078
jay745
jay745's Avatar
I knew super sports with stock shocks would be a bumpy nightmare. But I'm ok with it. Cheap and does a great job at the track and auto cross days I do.
You car would perform better with the oem springs if youre keeping the oem suspension. It's only a matter of time before the oem suspension blows on those lowering springs.
yellows are much stiffer and adjustable dampening.
Old 08-29-2016, 06:06 PM   #6079
SirClimax
SirClimax's Avatar
Drives: 2014 CSG GTI
On the softest setting they are supposed to be similar to oranges but I had them around 75% stiffness
"As the Spice Girls would say, Spice up Yo Life!" - robeeeerob
"Yeah but house stuff doesnt make your house go faster" - uglybastard
COBB Stage 2/SPM Turboback/IE Intake/Airlift Performance V2/Golf R Front Brakes/Tyrolsport Caliper Stiffening Kit/Slotted Rotors/Stoptech Pads/SS Lines/RBF600 Fluid/Neuspeed Rear Swaybar & Endlinks/VMR V701
SirClimax is offline   Reply With Quote
Old 08-29-2016, 06:28 PM   #6080
DASVDUB
DASVDUB's Avatar
I have the Koni oranges on. I guess I did word that weirdly.
Old 08-29-2016, 09:22 PM   #6081
uglybastard
uglybastard's Avatar
Originally Posted by D_Evl_GTI View Post
Thank you for your input sir I will definitely punctuate next time.
it is the difference between "Let's eat grandma" and "Let's eat, grandma"
..246.............. Insta
Old 08-29-2016, 09:23 PM   #6082
uglybastard
all this talk of stiffness and not one "that's what she said" in there.
Old 08-29-2016, 09:58 PM   #6083
SirClimax
SirClimax's Avatar
We were leaving that for you
Sent from my SAMSUNG-SM-G920A using Tapatalk
Old 08-29-2016, 10:05 PM   #6084
sterkrazzy
sterkrazzy's Avatar
Drives: mk6 gti
Grandma was delicious.
Old 08-29-2016, 10:27 PM   #6085
uglybastard
that's what she said.
Old 08-30-2016, 12:13 AM   #6086
davserbic
davserbic's Avatar
Drives: Golf MKVI
Hey,
Curious if anyone could comment who has had personal experience with Alphards 18x8.5 (et35) and 9.5 (et40) on a Mk6 w/ Bags.
Currently Im running ESR SR02s at 18x8.5 (et30) and 9.5 (et35) and am on coils. I rub in the rear here or there but nothing major.
Switching over to bags -- airlift slam series v2 and am considering Alphards for my setup. Any recommendations would be helpful. Im considering 215/40s all around.
Thanks in advance.
Golf 2.5L Build Thread | Airlift Slam Series + V2 Management | APR Carbonio | Mercedes Alphards | Golf R Conversion |
FOLLOW ME ON IG: @DAVSERBIC
davserbic is offline   Reply With Quote
Old 08-30-2016, 04:40 AM   #6087
snobrdrdan
Formula 2 Champion
snobrdrdan's Avatar
Drives: a VW
AWE or 42DD boost tap?
I've had both....go with the New South tap instead
http://www.esetuning.com/newsouth-pe...i-con-026.html
AWE requires you to butch up your OEM hose
42DD is nice, BUT because the nipple faces down the oil/blowby gets in the line (gravity) and clogs it up eventually. In the winter it freezes up too, because of that, mind you.
The New South just plugs right in, replacing the OEM hose, and the barb/tap is on the top of the hose with less blowby getting into the boost hose. It also has the "restrictor" built into the tap as well.
2017 Passat VR6
2017 Passat R-line
Old 08-30-2016, 04:42 AM   #6088
snobrdrdan
Formula 2 Champion
snobrdrdan's Avatar
Drives: a VW
x3 on the Koni Yellows
They're the better choice
2017 Passat VR6
2017 Passat R-line
Old 08-30-2016, 10:45 AM   #6089
sterkrazzy
sterkrazzy's Avatar
Drives: mk6 gti
Ah, I already have the 42dd on order and it shipped this morning. I bookmarked the new south tap though, if I have any problems I'll try that one. Thanks.
Old 08-30-2016, 04:38 PM   #6090
barnes93cb
barnes93cb's Avatar
Drives: '11 BMP 2Dr DSG GTI
I desire slotted rotors. Im planning to upgrade my pads to stoptech performance pads, and better fluid. I was thinking ECS cryo but those are a bit pricey.
What brand and where is cheapest for reliable slotted rotors?
APR Stage 2 / CTS Intake / Twintercooler / Godspeed Downpipe / MagnaFlow Catback / H&R Springs
APR Stage 2/ Lowered Build Thread
Instagram: barnes93_vw
barnes93cb is offline   Reply With Quote
