Old 06-26-2017, 10:55 PM   #7337
Jaber
Modero
Jaber's Avatar
Originally Posted by davserbic View Post
I know how to remove the trim for the radio but do not know how to remove the trim for the dash vents.
I looked for tutorials but nothing specific to the dash. I saw a GPS antenna install and someone mentioned two Torque screws are holding it down and then you can pull toward yourself to slide the ac vent out. Can anyone confirm if you can get to these nuts without having to remove the radio out or not?
Also how do you remove the side vents from the dash? Pry?
For the center vents, you need to remove the radio. Even if you don't have the screws holding it in, the radio helps hold it in.
Here are the two screw holes once radio is removed.
For the side vents, iirc they just pop out.
Member Journal
Old 06-26-2017, 10:57 PM   #7338
davserbic
davserbic's Avatar
Drives: Golf MKVI
Thanks a bunch boss!
Golf 2.5L Build Thread | Airlift Slam Series + V2 Management | APR Carbonio | Mercedes Alphards | Golf R Conversion |
FOLLOW ME ON IG: @DAVSERBIC
davserbic is offline   Reply With Quote
Old 06-27-2017, 11:24 PM   #7339
KDOG
Drives: CSG GTI
Made a thread on codes it threw, but anyone have any experiences like this? I cant find a single thing online about it. DSG 2010 gti, was coasting to a stop in manual, I felt something disengage.. had no power to wheels engine revved, shifted throughout PRNDS and manual with no jump or any wheel movement, restarted many times, nothing. I will find out tomorrow what is wrong its at dealer now, just so confused.. I recently had a new mechatronics and clutch packs put in, so I'm not sure what it could be, the code it threw was 2 problems shifting codes. P0829 5-6 shift and P0784 4-5 Shift, I cant find a single thing online besides it is a shifting code.
KDOG is offline   Reply With Quote
Old 06-29-2017, 03:41 PM   #7340
davserbic
davserbic's Avatar
Drives: Golf MKVI
I get PM notifications through Tapatalk that a message was received but when I check my inbox through GolfMk6 — there are no new messages. The message is not even there but can see and read them through Tapatalk?
Anyone else have this going on?!
Old 06-29-2017, 04:51 PM   #7341
brobst
brobst's Avatar
Drives: CSG mk6 6MT
Sometimes when tapatalk updates, it makes your old messages have notificafion again. Other option is your inbox is full
Old 06-29-2017, 07:31 PM   #7342
SirClimax
SirClimax's Avatar
Drives: 2014 CSG GTI
I get PM notifications through Tapatalk that a message was received but when I check my inbox through GolfMk6 there are no new messages. The message is not even there but can see and read them through Tapatalk?
If I remember correctly taptalk has a chat feature so if the message is through the taptalk chat is won't be in your golfmk6 inbox.
"As the Spice Girls would say, Spice up Yo Life!" - robeeeerob
"Yeah but house stuff doesnt make your house go faster" - uglybastard
COBB Stage 2/SPM Turboback/IE Intake/Airlift Performance V2/Golf R Front Brakes/Tyrolsport Caliper Stiffening Kit/Slotted Rotors/Stoptech Pads/SS Lines/RBF600 Fluid/Neuspeed Rear Swaybar & Endlinks/VMR V701
SirClimax is offline   Reply With Quote
Old 06-29-2017, 08:39 PM   #7343
KDOG
Drives: CSG GTI
Just learned I have to get a whole new DSG trans.. had a question though, there is an inspector coming out to approve the work in the next couple days, since it is such a pricey install, I am putting stock air box back in tomorrow just to be safe.. trans mount is out and only other mod is cosmetic things and r8 coils.. I was tuned, and I went back to stock 5 days prior to bringing it in, since doing so is there any way for the inspector to check or tell that I had an APR stage 1 tune on the car?
Old 06-29-2017, 09:15 PM   #7344
jebusfreek666
Drives: 2012 Golf GTI
I bought a mount for my phone, and had it stuck to the trim next to the radio in my car with the double sided foam tape that came with the phone mount. Sitting it the sun, with the phone sitting in it, it fell off. Does anyone have a non-permanent idea for what to use instead of the double sided foam tape? I thought about command strips, but they only hold 2-5 pounds and the mount is spring loaded to hold the phone. So I have to push up against it fairly hard.
Or would it be easier/cheaper to just super glue or use screws and then just replace the trim if I sell it or get a new mount?
jebusfreek666 is offline   Reply With Quote
Old 06-29-2017, 09:23 PM   #7345
Rickybobbi
try the gorilla double sided tape..its clear and can hold 10 pounds i believe or maybe more
2011 GOLF 2.5// LED TAILS // 18" BLACK RIMS // 2 12" KICKER SUBS // REAR EMBLEM BLACKED OUT // FRONT EMBLEM BLACKED OUT // DE-BADGE REAR // LED INTERIOR // HID HEADLIGHTS // 8" ANDROID HEAD UNIT // 35% TINT ALL AROUND // FK STREETLINES //
Old 06-29-2017, 09:31 PM   #7346
DASVDUB
DASVDUB's Avatar
IIRC any change done to the ECU is logged whether you go back to stock or not.
Old 06-29-2017, 09:47 PM   #7347
Rickybobbi
does tuning your car void the warranty?
Old 06-29-2017, 09:57 PM   #7348
KDOG
Drives: CSG GTI
How hard is it to check this? does it "pop up" or very easily noticeable when checking? or is it quite a bit of trouble to do this?/ pain to do
Old 06-29-2017, 10:28 PM   #7349
DASVDUB
DASVDUB's Avatar
Depends on the dealership lol
Old 06-29-2017, 10:29 PM   #7350
DASVDUB
DASVDUB's Avatar
I'm sure they'll look for it on a performance car lol.
