Old 12-13-2017, 07:39 PM   #7771
sterkrazzy
sterkrazzy's Avatar
Drives: mk6 gti
Originally Posted by Boscogn View Post
What's that cost per wheel? I need this done.
I've seen shops do it as cheap as $75, like if a sale was going on or something like that. Typically it seems to be about $100-110 a wheel. I'm being charged $125 per wheel, plus $20 per wheel for unmount/remount tires plus rebalancing, and I have one wheel with a bit of curb damage they're repairing for free, so altogether $580.
I want to do candy red, so he said that's a tristage job that takes a few days to do and takes more time and materials, so it's a little bit more per wheel.
Old 12-14-2017, 07:03 PM   #7772
uglybastard
uglybastard's Avatar
Originally Posted by sterkrazzy View Post
Ya, the oem pzero all seasons. I'll have to take a closer look at them this weekend.
put 'em on and do burnouts.
..246.............. Insta
Old 12-14-2017, 07:19 PM   #7773
notovicrious
notovicrious's Avatar
Drives: 2011 GTi 2.0T
I run em except now when in winter mode but I have in winter and theyíre solid. Definitely no stick for track day but theyíre not for the track so I ainít mad at em. LETS GOOO!!!
Old 12-15-2017, 02:30 AM   #7774
Dub_Polo
Dub_Polo's Avatar
Drives: 2011 GTI DSG
I am Cobb OTS stage 1+ tune and am used to seeing boost around 16-17 psi but now for some reason whenever I go WOT I’m only about 14 and sometimes hit 15, but rarely. What could be the problem? The DV?
Mk6 Gti DSG l COBB Stage 1+ l BSH Race Intake l R8 Coils l Raceland Ultimos l
Dub_Polo is offline   Reply With Quote
Old 12-15-2017, 08:07 AM   #7775
brobst
brobst's Avatar
Drives: CSG mk6 6MT
Its colder. You need less boost since the air is denser. Now if this just happened then yeah I would check out dv Oring
brobst is online now   Reply With Quote
Old 12-15-2017, 09:10 AM   #7776
lilonespaz
lilonespaz's Avatar
Originally Posted by Dub_Polo View Post
I am Cobb OTS stage 1+ tune and am used to seeing boost around 16-17 psi but now for some reason whenever I go WOT Iím only about 14 and sometimes hit 15, but rarely. What could be the problem? The DV?
cold air. Is denser than warm air so less boost is needed.
Old 12-15-2017, 01:34 PM   #7777
Dub_Polo
Dub_Polo's Avatar
Gotcha I was just worried, but do plan on investing on a GFB DV+ soon just incase.
Old 12-15-2017, 05:14 PM   #7778
Grant@COBB Tuning
Drives: '13 | GTI 2DR | 6spd | Candy White
Hey Dub_Polo! As already stated cold air is denser so it is normal to see lower boost numbers in cold weather.
15psi is still pretty normal for our OTS stage 1+ map which targets for 17psi with a variance of +/- 2psi.
https://cobbtuning.atlassian.net/wik...es+for+MK6+GTI
Grant@COBB Tuning is offline   Reply With Quote
Old 12-15-2017, 05:20 PM   #7779
brobst
brobst's Avatar
Drives: CSG mk6 6MT
Yeah your car is most likely load target tuned so psi will change to meet the load. This pid loop control is better for variations in fuel, climate, and other unforseen variables.
Old 12-18-2017, 04:18 PM   #7780
robin8tor
robin8tor's Avatar
Drives: 2010 GTI 6MT UG 2dr
So here's my stupid question. 2010 GTI, 123,xxx miles, 6mt. Everything is stock except a Magnaflow CBA, no tune.
In the last month, I've had two coil packs go randomly. Both times it happened in 3rd gear around 2.5-3k rpm, under moderate to heavy acceleration out of a corner. It felt like it started to build boost, then a pop, CEL, misfiring. Is this normal of coil packs to wear out and fail like this, is it an indicator of a larger issue?
Thanks in advance.
2010 GTI - Brokeswagen
1978 CJ5 - Humpty Dumpty
robin8tor is offline   Reply With Quote
Old 12-18-2017, 05:08 PM   #7781
lilonespaz
lilonespaz's Avatar
Thanks in advance.
If they are original coil packs yes. 125k miles is a bit. I changed mine at 60k and will again at probably 100k just for funsies.
Get The Audi r8 red top coils (about same price as oem VW) they are a little stronger.
Old 12-18-2017, 06:48 PM   #7782
realcyberbob
realcyberbob's Avatar
Thanks in advance.
Switch them all to R8 coil packs and you shouldn't have any more failures, stock ones stop working regularly.
Old 12-18-2017, 10:11 PM   #7783
SirClimax
SirClimax's Avatar
Drives: 2014 CSG GTI
Here's a question that is the definition of this threads origins: What is the top speed at which you can set cruise control?
Sent from my SAMSUNG-SM-G920A using Tapatalk
"As the Spice Girls would say, Spice up Yo Life!" - robeeeerob
"Yeah but house stuff doesnt make your house go faster" - uglybastard
COBB Stage 2/SPM Turboback/IE Intake/Airlift Performance V2/Golf R Front Brakes/Tyrolsport Caliper Stiffening Kit/Slotted Rotors/Stoptech Pads/SS Lines/RBF600 Fluid/Neuspeed Rear Swaybar & Endlinks/VMR V701
SirClimax is offline   Reply With Quote
Old 12-18-2017, 10:15 PM   #7784
realcyberbob
I would assume cruise control is not limited by top speed, but there's only 1 way to find out...
