A few bits of info on spring pressure and preload:
1. As was suggested above you want your spring pressure around half of the max boost you will run. Maximum boost pressure is 2.5 times spring before you just can't effectively control boost electronically. So having a 5psi WG spring is not ideal. I think a lot of kits come with this because they are designed to not upset a canned tune too much and overboost. An ideal spring pressure for above 20psi of boost is 10-14psi.
2. Preload dictates spiking and boost ramp. I recommend 2-3 millimeteres of preload and no more. Adding more will increase spiking on boost onset but will not help hold more boost as that is the spring constant that does not change.
3. The variations I have seen between K04 kits does not look to me like it is intercooler related. After tuning thousands of cars over the years, I can tell you boost response is not going to be significantly changed by the FMIC as we are seeing here. Yes, some slight variation is normal but not like Im seeing between cars. What I am seeing suggests that some of these kits come with stronger springs than others. If you're installing a new kit it might be worth checking cracking spring pressure and preload before putting it on using a hand pump.
I guess what it comes down to, is im just looking for definitive math. I got port n polish k04, with the crack pressure set to factory 6psi. I have apr IC and upgraded boost pipes (outlet and throttle body). Now lets put tune aside and assume the appropriate tune. Right now I have 23psi taper to 20 with ~90%wgdc at some intermediate part of the pull.
If I add a forge wastegate and adjust the tune, am I going to make more power?
And if I get more psi out of the k04, is it useful pressure or way past efficiency pressure?
If I can get a definite yes or no to this question, my next mod will be the 3bar map sensor and forge wastegate
I'm K04 and don't have a 3 BAR. Alex explicitly told me in an email it was not necessary at this point.For some reason I thought most K04 tunes required the 3bar map sensor? I'm not K04 yet but eventually.
That was before the new WGA so maybe it's changed but he still hasn't suggested one. FYI.
Sent from my HTC 10 using Tapatalk
Cool thanks! So does more apply to the BT setups?
Quick review now that my tune is complete.
Compared to COBB OTS Stage 2 Stock MAF, the car is faster, smoother, and sounds amazing with the crackles. I gained a few PSI over the COBB map and the entire power band has extra pull to it. It feels like I have constant boost that holds much better throughout a pull. Shifts are smoother (manual) and everything just feels "right." The COBB tune was far from bad, but this tune made me love my car even more.
i dont no numbers. (and im high torque stratified) but stratified tune is 100X smoother than cobbs OTS tune.Does anyone know how the OTS cobb map compares to the low torque file from stratified? Or what kind of numbers it obtains.
