Old 06-19-2017, 08:47 PM   #449
riceburner
Drives: 2012 GTI DSG / K04
those seats wow!! <3 and whole car of course!
Old 06-19-2017, 08:57 PM   #450
HYDE16
HYDE16's Avatar
Drives: 2011 MK6
Thank you.
Facebook: Ryan Jacobs
Instagram:@becauseHYDE16
YouTube: HYDE16
Old 06-21-2017, 11:45 AM   #451
riceburner
the more i read into your stuff the more i want to just copycat everything loool. I just went ahead and purchased dei tape for my intake, PTP exhaust wrap, and the treadstone MAF air straightener.
Will very soon be likely purchasing the MK5 R32 Belly tray, and posssibly a turbo blanket as well. I'm a huge advocate for keeping things cool. Would certainly go the aquamist meth route but think i'm going snow stage 2 instead.
Sorry to derail and make it about my build but the inspiration is following yours haha.
Thanks for sharing all the info you do, it's appreciated.
Old 06-23-2017, 04:16 PM   #452
HYDE16
HYDE16's Avatar
Drives: 2011 MK6
you are welcome, everything you discussed above is a good choice to adding incremental changes to your build. Keep it cool to prolong the power.
YouTube: HYDE16
Old 07-03-2017, 04:16 PM   #453
skotcoop
skotcoop's Avatar
Drives: 4DR CW 2012 GTI 6SPD
You're still running the VWR subframe mounts? Been thinking about changing mine. I'm running stock upper and 034 lower pucks at the moment. But I don't want anymore noise than I have, which I think is mostly coming from my BFI stage 3 clutch(which is now slipping and I'm getting the stage 2 SB daily soon). Not sure what to do about the pendulum mount either.
2012 6spd GTI CW /APR stage 2 cast dp & tune/Uni CAI/Neuspeed charge&discharge pipe/GFB DV+/BFI Stg 3/Wavetrac LSD/H&R FSB 26mm/Dieselgeeks/tyrolsport/034 mounts/fluidampr/Raceseng/OEM tinted LED tails/LCA bushings/PolarFIS My build thread http://www.golfmk6.com/forums/showthread.php?t=96882
skotcoop is offline   Reply With Quote
Old 07-03-2017, 05:26 PM   #454
HYDE16
HYDE16's Avatar
Drives: 2011 MK6
I found the engine and trans mounts controlled the trans/clutch noise. BFI was the loudest. 034 street has been a blessing. When paired with the VWR subframe mount(s), it's been sublime.
YouTube: HYDE16
Old 07-13-2017, 01:16 PM   #455
HYDE16
HYDE16's Avatar
Drives: 2011 MK6
Full bolt in fire extinguisher, under seat mount and quick detach system for sale: http://www.golfmk6.com/forums/showthread.php?t=112547
YouTube: HYDE16
Old 07-26-2017, 03:00 PM   #456
HYDE16
HYDE16's Avatar
Drives: 2011 MK6
Build thread has been updated with the latest and photos posted on IG @becauseHYDE16; changes include:
-Advanti Racing Storm S1 17"x9" ET45 Wheels & Bridgestone Potenza RE-71R 245/40/17 Tires
-Corbeau RRB Seats
-GS Auto Solutions – Push Clutch to Start Bypass Harness
-Innovate Motorsports EBC-1 all in one gauge (sold off the AEM Digital Wideband UEGO AFR Gauge, AEM Water/Methanol Flow Gauge and Greddy Profec boost controller)
-Raceseng Circuit Series Shift Knob (review hyperlink on first page)
-SuperPro Performance End Links
-SuperPro Roll Centre Adjusting Ball Joint
-Swift Rear 400lb Progressive Springs
-WhanAB Billet Aluminum Dipstick Handle
I have the following for sale as well:
-H3R Performance HG250B Clean Agent Fire Extinguisher with Rennline Quick Disconnect Fire Extinguisher Mount
-Whiteline Rear Sway Bar End Links
Car was recently featured at Waterfest 23’s and in PASMAG Waterfest 23, July 2017
YouTube: HYDE16
Old 09-08-2017, 07:47 PM   #457
HYDE16
HYDE16's Avatar
Drives: 2011 MK6
Keeping this thread up to date, several changes over the past few weeks; full photo coverage posted on IG @becauseHYDE16
-ZZP Opel injectors swapped out for 8V S3 / MK7 Golf R injectors (slightly less flow but better spray pattern and drivability)
-Turbosmart diverter valve installed
-Engine bay topside fuel line converted to PTFE SS -6AN line & port fuel injectors connected
-New 2-stage Aquamist water methanol layout installed (post intercooler jet vs. direct port methanol jets)
-AEM AFR gauge removed, Innovate ECB-1 installed to monitor ethanol %, fuel temp, 4-bar boost, AFR
-Neuspeed turbo outlet pipe extended to remove the OEM green o-ring gasket connection to the Pag Parts true FMIC
-All worm gear clamps from the turbo compressor outlet through the turbo outlet pipe replaced with T-bolt clamps
-Throttle body coupler worm gear clamps replaced with T-bolt clamps
-New Eurodyne file with CAM 2 timing map smoothed out, revised LPFP duty cycle MAP and revised N75 duty cycle MAP for HIGHER boost (~26psi)
-New Torqbyte GPO1 MAP to support higher boost with twin 1,000cc split stream Bosch EV14 injectors
-New Torqbyte MAIN MAP to provide cooling through the 1.2mm Aquamist post intercooler jet (triggers at 8-10psi)
-New Torqbyte GPO2 MAP to turn on the second stage of water methanol through direct port Aquamist jets (triggers at 20psi for now)
Time to continue logging and watching AFR to dial in port fuel so we can keep increasing boost levels to 30+ psi. The car is an absolute monster.
Next up, 2K mile engine break in sample of Brad Penn racing oil going out to Blackstone Labs and Brad Pennís lead engineer for results and future oil recommendations and the Ecliptech Shift-P2+ installation and review.
YouTube: HYDE16
Old 09-09-2017, 08:34 PM   #458
zef
Nasty dude. Who powder coated your valve cover? I thought the TSI guys couldn't do that.
'13 GTI CW 2 DR (DSG) - Eurodyne Stage 2/HPA DSG Tune | Cobb TBE | IE CAI | IE FDS IC | 034 CC | VWR Subframe Pucks | 034 SD Mounts | MSS SPRING KIT (learn more here) | 034 Pendulum Mount | Supaloy Control Arms | B6 Passat Front Spindles | Koni Yellows | RSE10 | more to come! Follow me on Instagram!: jg_gti
Old 09-09-2017, 08:37 PM   #459
HYDE16
HYDE16's Avatar
Drives: 2011 MK6
Has to be done a certain way. Pag Parts Turbo in Deer Park, NY powder coated it through a local vendor.
YouTube: HYDE16
Old 09-11-2017, 12:35 PM   #460
Drives: 10 GTI CSG DSG K04 4DR 130k+
Very nice. What kind of HP are you thinking now?
Old 09-11-2017, 02:40 PM   #461
HYDE16
HYDE16's Avatar
Drives: 2011 MK6
Based on MAF value extrapolation, we should be easily over 400HP. Based on boost level and fueling requirement we are approaching 450HP. As I log and dial in port fuel, we flash increased boost Eurodyne files to bring peak boost up to 30+ psi.
YouTube: HYDE16
