Leo_Freitas
Thank you mateMuch brighter and a pure white, instead of bluish. I had eds reps before....
Just ordered. It will look just like this in my car. I got a white one too.Much brighter and a pure white, instead of bluish. I had eds reps before....
My car is equipped with D1s bulb, does it mean it is not compatible with my car?
If you have oem projectors then no these won't work on your car. Osram is working on a set so people with oem projectors can use these.
These still aren't available? Ive been watching this thread since I joined the site...
I got myself a pair. These look really really good. But I am experiencing a problem here.
After turning on the low beam for couple minutes while driving, the Bulb failure indicator will be on and says "check front side light", and my right side DRL and fog light stops working. Low beam / high beam still works. Restart the engine and the problem is gone temporarily.
Anyone having a similar problem?
Good thing there is one year warranty and I will check with the manufacturer.
Do you have a canbus cable to give us your
Do you mean using Vag Com cable to diagnose? I haven't had experience with that yet, but I guess it's a necessary set up now.
I got a OBDII scanner. Does that help?
Do you have a recommendation on which diagnostic setup to buy? Link/thread is appreciated!
Thanks
