Powdercoated Boxster 986 Calipers for NQSBBK
lleron
SOLD
I had this set powdercoated by a local shop who didn't mask them properly when sandblasting and coating the calipers. I bought a replacement set in the mean-time while they sent them to a local brembo rebuilder who cleaned the bores and rebuilt them with brand new seals and refurbished pistons and pressure tested them.
They've not been installed since and include a used set of brake pads from the original boxster (which I would probably replace) and all hardware including an extra set of pistons and the original seals and brake wear sensors as well as a set of brembo stickers. To mount these you'll need a set of brake lines with the flare for these calipers and the creations motorsports brackets. These fit the OEM rotors, so for ~$500 you can have a great brake set up with better feel.
More information here for those unfamiliar with the setup: http://www.golfmk6.com/forums/showthread.php?t=36589
gti3527
310 shipped/paypalled
Pm'd you... Do these fit with stock wheels?
Sent from my LG-H872 using Tapatalk
lleron
FYI for those interested, these will need 5-10mm spacers depending on the stock wheel. I have 8mm which clear the stock golf R wheels and may have been able to get away with 5mm.
lleron
So I understand correctly, these were rebuilt or need to be rebuilt?
They were fully rebuilt with new seals, dust seals, and refurbished pistons after they cleaned up the bores and were then pressure tested. They haven't been mounted or run at all since the rebuild. The seals to rebuilt these are ~$160+ alone.
ZiggyMKVI
Man i would jump on these if I hadn't bought a motorcycle last month.
Bump for a good price
