Old 03-20-2016, 08:06 AM   #1
07stuntin6r
Mk6 oil pan bolt
Okay so went to change my oil long story short the damn drain plug was so tight I stripped the hex and now can't get it off. Any tricks I could do? Hard not being a regular bolt but I was wondering if I could take the oil pan off loosen the bolt from the inside and then get a new one. Gasket be reusable? Car has 30k miles on it so prev oil was all done by dealer. Thanks!
07stuntin6r is offline   Reply With Quote
Old 03-20-2016, 08:36 AM   #2
HYDE16
HYDE16's Avatar
Drives: 2011 MK6
big ass channel locks will take it off.
Facebook: Ryan Jacobs
Instagram:@becauseHYDE16
YouTube: HYDE16
Old 03-20-2016, 08:55 AM   #3
luvdagators
luvdagators's Avatar
Drives: 13 CW Autobahn GTI (o\!/o)
Location: Corner of grey street and the end of the world NC
Best money you will ever spend
luvdagators is offline   Reply With Quote
Old 03-20-2016, 09:10 AM   #4
Yes, you could use an oil extractor. Big channel locks, or vise grips could work. I wouldn't drop the pan, that won't help. Do you have the right metric sockets? A good 6 point should have got it loose. Have a new bolt/washer on hand, the seal is reusable if you don't overtighten it.
Old 03-20-2016, 09:28 AM   #5
baniels
baniels's Avatar
Drives: 2010 4dr 6MT GTI
Get yourself one of THESE for next time.
2010 6MT 4DR GIAC Stage 2 RSR Clutch CTS Turbo Catted DP IE Intake 034 Dogbone Insert Audio Upgrades
baniels is offline   Reply With Quote
Old 03-20-2016, 10:41 AM   #6
07stuntin6r
Mk6 oil pan bolt
I've change my oil once before never had an issue until this time. Trying to figure out how I'm gonna get channel locks around the bolt since there isn't much room to work with as far as surface area. Might order that valve and wait for it to come in then try it. Cars at 12k on this oil just wanted to change it before I put another 1k. Should be fine tho...the bolt is a hex key so not a traditional drain plug
Old 03-20-2016, 12:25 PM   #7
07stuntin6r
T
Ordered one $55 shipped....beats jacking up the car plus I guess I can use it for brakes etc
Old 03-20-2016, 01:54 PM   #8
Geryon86
Geryon86's Avatar
Drives: MK7 R
Just need an easy out, no cutting or bending. Tap it in and slowly turn. Had the same happen to me. See below. The gasket is not reusable since it is a liquid silicone sealant.
16' LB R | DSG | APR Stage II HT |
11' SB GTI
|DSG|APR v3.1|CTS K04|
Geryon86 is offline   Reply With Quote
Old 03-20-2016, 01:59 PM   #9
luvdagators
T
Yes sir makes changing oil a snap I love mine!
Old 03-20-2016, 02:42 PM   #10
kern417
Drives: '09 Jetta
my old oil pan had a hex bolt and my new pan came with torx. i plan on switching back at some point because i'm nervous the same thing will happen to me.
https://www.ecstuning.com/ES1306602/
do a burnout.
Old 03-23-2016, 04:28 PM   #11
07stuntin6r
Yeah instead of dealing with it I'll leave it and change from the top from now on. It's so nice to do it this way!!! Mind F shocked how much oil my engine burned up....wanna say atleast 2qts
Old 03-23-2016, 04:40 PM   #12
Geryon86
Geryon86's Avatar
Drives: MK7 R
Mind F shocked how much oil my engine burned up....wanna say at least 2qts
Or maybe you're not getting all of the oil out.
11' SB GTI
Old 03-23-2016, 07:45 PM   #13
uglybastard
uglybastard's Avatar
This. or you may have a leak somewhere.
When you use your extractor, do you uncap at the engine top while pulling from dipstick tube? or is the line possibly flat against the bottom? try pushing and twisting to see if you can get in further?
..246.............. Insta
Old 03-23-2016, 08:11 PM   #14
luvdagators
Make sure to extract oil at operating temp
