Is that cause of the MAF? I have that too but it's getting better through the revisions.Is the maf calibration the same as the datalog refinement as that is an added charge?
Getting this to the UK...postage will be a pain.
Really fed up with the buckle/jerk when slowing down at roundabouts and quick accelerating.
Sent from my HTC 10 using Tapatalk
I've been waiting 1.5 weeks for some sort of response regarding my protune logs and some problems/stalling I've been having with multiple emails sent. It's a bit frustrating when there's responses on facebook and sales here but no responses to paying customers spending $300+.
maf calibrations is free and included in the tune. You send a data log and they make sure you are getting proper readings from your maf and over all that the tune is generally "Safe"Is the maf calibration the same as the datalog refinement as that is an added charge?
You should be good. About the same mods I have, minus the Forge BOV. Good luck!
Thanks for the response! I have a few more questions if you don't mind.
1) How's your clutch holding up with the tune? I'm assuming you're on the stock clutch.
2) Do I NEED and intake? I know I definitely need the upgraded DV and I should get the R8 coil packs with spark plugs for a preventative issue. I don't want to get it all in one shot if I don't have to. But would an intake limit me drastically?
p.s. Winter is rolling around so it's not blistering hot or even above 50 degrees F so I don't think I'll be heat-soaking too bad on my school/work commute.
Thanks.
Wonder if there will be a black friday deal....waiting till then to get my tune/ap
Scroll up. They posted it.
Thanks.
See aboveWonder if there will be a black friday deal....waiting till then to get my tune/ap
I saw you saw above but i highly doubt they will go any cheaper on tunes but who knows.I saw, it's prior to black Friday though, and just the "beginning"
I wouldn't count on the ap/tune being cheaper.
