Old 06-18-2017, 05:39 PM   #1
Motrellim
Motrellim's Avatar
Drives: 2012 GTI Shadow Blue
Helix soundbox balance problem
I had my soundbox installed by a stereo shop. I noticed after it was installed that the sound just wasn't right. Also the front speakers were louder then the rear. So I'm thinking it just needs to be programmed. I got it programmed at a dealership. All that did was make my subwoofer sound better. So I did a balance check. It turns out that only the right channel is coming out of all 8 speakers and the front speakers are still louder then the front. Anybody know if it was installed or programmed correctly?
Sent from my VS995 using Tapatalk
Motrellim is offline   Reply With Quote
Old 06-19-2017, 08:54 AM   #2
lilonespaz
lilonespaz's Avatar
take it back to where you got it installed and let them know its not performing properly and would like it fixed.
Old 06-19-2017, 10:00 AM   #3
Motrellim
Motrellim's Avatar
I did they say they installed it right. They told me to find out what could possibly be wrong with it and let them know
Old 06-19-2017, 11:11 AM   #4
lilonespaz
lilonespaz's Avatar
what? lol did you talk to a manager... have them sit in your car and be like how the fuck could this be right? I would want compensation if they arent willing to fix it.
Old 06-19-2017, 11:17 AM   #5
Motrellim
Motrellim's Avatar
They said it might be the amp.
Old 06-19-2017, 11:34 AM   #6
lilonespaz
lilonespaz's Avatar
yeah i would be like well something is wrong so please fix it and if you cant thing there needs to be a offer of something else to replace it or fix it or compensation or something.. but always lead off with that you just want it working properly.
Old 06-19-2017, 11:35 AM   #7
Motrellim
Motrellim's Avatar
Installing the soundbox in an MK6 GTi 2-door they don't have to repin any wires?
Old 06-20-2017, 02:13 AM   #8
snobrdrdan
Formula 2 Champion
snobrdrdan's Avatar
Drives: a VW
Not many dealers (if at all) have the programmer on hand. Was it truly coded?
There are some guys on golfmk7.com that rent it out for $15 or $20. My advice would be to rent the programmer & code it for a 2 door MK6 specifically (file #43 on the SD card)
See here:
http://www.golfmk7.com/forums/showthread.php?t=28448
or
http://www.golfmk7.com/forums/showthread.php?t=29190
2017 Passat VR6
2017 Passat R-line
Old 06-20-2017, 02:31 AM   #9
Motrellim
Motrellim's Avatar
Yes a dealership coded it. I'm just wondering if wires need to be repined or not because I have a two door MK6 GTi
Old 06-20-2017, 02:54 AM   #10
snobrdrdan
Formula 2 Champion
snobrdrdan's Avatar
Drives: a VW
You have to depin a couple wires on the radio harness & then insert the Helix harness wires instead.
And there are special harnesses used on the older radio, in your MK6
It's plug & play essentially & only installs one way. (it'd be pretty hard to screw up)
If they didn't do that right....it wouldn't be working at all (your door speakers or the Helix).
Did they change the balance/fader at all?
2017 Passat VR6
2017 Passat R-line
Old 06-24-2017, 01:25 AM   #11
Motrellim
Motrellim's Avatar
Hello, thanks for the response. If they didn't change the brown and black wire what would happen? Would it turn on at all? When you asked if they
Old 06-24-2017, 01:30 AM   #12
Motrellim
Motrellim's Avatar
Hi, thanks for the response. What would happen if they did not repin in the wires? Also I don't understand when you asked if they changed the balance\ fader. You can change that?
Old 06-24-2017, 03:28 AM   #13
snobrdrdan
Formula 2 Champion
snobrdrdan's Avatar
Drives: a VW
If they didn't repin it, it wouldn't work (that's where the Helix is getting power from)
And the balance/fader is done thru the radio itself
(left & right and front & back adjustments)
That picture above is from VW as a "tech tip" for the techs at the dealership when installing. I'd take it back to the stereo shop and show them to confirm that it's hooked up properly.
2017 Passat VR6
2017 Passat R-line
Old 06-24-2017, 05:53 AM   #14
beygan
Drives: GTI 2013
Congrats on your install. I bought a helix soundbox but haven't gone around to having it installed. The dealership kept avoiding my queries of installation for some reason. Hopefully your amp isn't faulty. It could be the programming. How much did your shop charge you for the install?
'13 GTI 3-Door
K&N Intake
FK Coilovers
APR Stage 1
beygan is offline   Reply With Quote
