Old 02-13-2016, 07:23 PM   #15
mr wrong
Drives: 2017 Golf Alltrack
How is this any different or better than any other pendulum bracket out there?
2017 Golf Alltrack - JB4 -
mr wrong is online now   Reply With Quote
Old 02-13-2016, 07:45 PM   #16
Speeddemon69
Drives: 2012 MK6 GTI
So with this I don't need an insert?
Old 02-16-2016, 10:22 AM   #17
Arin@APR
GolfMK6 Official Vendor
Arin@APR's Avatar
Drives: B8 S4 & MK5 GTI
Originally Posted by egti View Post
Any chance Arin can post the installation manual? Just want to make sure it is something that I, a not so handy guy, can manage.
By the way, I do have the BFI Stage 1 insert. Can I use that together with this?
Thanks.
Remove the 3 bolts holding the OEM mount into place.
Slide out the old, slide in the new.
Install the 3 new ARP bolts and you're done.
Old 02-16-2016, 10:40 AM   #18
Arin@APR
Arin@APR's Avatar
Ours is different in several ways.
The first thing we did was upgrade the rear mounting point to the MK7 style mount. It's the shorter chunk on the back of the mount:
This is the same design used on the MK7 Golf R. VAG upgraded to this design as the previous design was prone to failure. Every other mount out there uses the OEM style in one way or another. Most just replace it with a flat piece of billet. The issue is when launching the car or driving really hard, it's easy to rip the bolts out and damage or destroy the transmission case. We did it countless times on the race cars. The new design all but eliminates this from happening.
Second, most everything on the market uses some sort of poly bushing. Poly bushings still allow flex and they can wear quickly. We went with a high quality PTFE lines spherical bearing. Spherical bearings create a solid connection but still allow the necessary movement which stiffens the mount up far more than a poly bushing. The bearing is fully serviceable. Do note, the reason you can't just install a solid piece of billet is there must be movement. A spherical bearing give you that smooth movement, whereas the factory and upgraded poly mounts provide the movement by essentially bending and squishing the connection points within the rubber/poly core.
Third, we're using ARP bolts, the leading bolt manufacturer in the racing world. (Not APR). The factory bolts are one time use. If you remove them, they are designed to go in the trash. Some don't provide replacement the bolts at all. they are strong and can be used countless times without replacement.
Fourth, we include instructions. Most don't take the time to do this. We do, and we're here on the phones should you have a question.
Fifth, we have over 400 dealers worldwide who are more than capable of doing the install for you.
Sixth, something not right? We're only a phone call, email, or click away.
Old 02-25-2016, 11:26 PM   #19
mark986
Drives: 2010 VW GTI
Got suckered into ordering one since I haven't bought anything APR in awhile. We shall see if it was a good buy
APR Stage I & 2 Intake | APR K04 | APR Downpipe |APR FMIC | R Tail-Lights | Rev. D
mark986 is offline   Reply With Quote
Old 02-26-2016, 03:48 PM   #20
Verserk-MK6
Drives: 2011 CSG 4 door AB 6 speed GTI
Have you done any testing with aftermarket sub frame mounts? for example vwr's mount?
Interested in the nvh of course.
Verserk-MK6 is offline   Reply With Quote
Old 02-26-2016, 08:57 PM   #21
nafljhy
Drives: 2011 UG GTI
wonder how this compares to 034 billet? arin?
Old 02-26-2016, 09:38 PM   #22
GroceriesVR6
GroceriesVR6's Avatar
Drives: One bagged, One static
Interested in this as well as I had the 034 Billet and the vibes were crazy.
Unitronic Stage 2|Unitronic Intake|Unitronic Intercooler|Unitronic DV Relocate|Unitronic Stage 2 DSG|Double Apex Carbon Paddle Extensions|GFB DV+|APR catch can kit|034 Billet Aluminum Mounts| APR Billet Dogbone Mount|R8 Coilpacks|Unitronic Turboback|Air Lift Performance|Unibrace XBJ| Unibrace UB|KMD Upper & Lower Rear Braces|Passat Subframe Swap|WALK|Front & Rear Brembo BBK|Fluidampr|IE Forged Rods|Supertech Valve Springs|VMR V810s
GroceriesVR6 is offline   Reply With Quote
Old 03-09-2016, 10:22 PM   #23
mark986
Drives: 2010 VW GTI
Anyone install there's yet? I'll have mine installed Friday. Curious on people's opinions.
Old 03-10-2016, 01:32 PM   #24
nafljhy
Drives: 2011 UG GTI
really? mine were actually very manageable, but then again i have a few other things installed too :x
Old 03-10-2016, 05:56 PM   #25
pashley
pashley's Avatar
Drives: 2011 GTI DSG black
Looking forward to some reviews. Anyone?
APR k04 - APR full carbonio intake - CTS TBE/TOP/TBP - do88 IC - fluidampr - ST X coilovers - H&R f/r sways - SuperPro ALK/ball joints - TyrolSport deadset kit - 034 upper strut/engine/trans mounts/SS brake lines/billet dogbone - R8 coilpacks/NGK plugs - MODA MD18s - Hankook Ventus V12 Evo2 - various cosmetic mods
pashley is offline   Reply With Quote
Old 03-10-2016, 09:26 PM   #26
mark986
Drives: 2010 VW GTI
I'll have time to install it tomorrow or Saturday. Will let you know.
Old 03-15-2016, 05:31 PM   #27
nafljhy
Drives: 2011 UG GTI
bump! arin any answers to my question?
Old 03-18-2016, 07:42 AM   #28
timneedscoffee10
timneedscoffee10's Avatar
Drives: 2011 VW GTI w Sunroof
Very excited about this - just ordered mine. I've torn those rear bolts out of the transmission casing 3 times now, once while pretty far from home.
I have the HPA red puck - so I'm anxious to see how bad the vibrations are ... but will know next weekend!
